It is currently Thu Oct 19, 2017 6:56 pm
 Post subject: 13" Wheels
PostPosted: Thu Sep 06, 2001 11:00 am
I could have swore the '89-91 Canadian Turbo Firefly's ran with 13" wheels and have the same brakes as the GTi ...<br><br>Is it true that 13" wheels won't fit on a GTi?<br><br>I pulled the front and it definitely does look it would be tight.<br><br> <p></p><i></i>
 Post subject: Re: 13" Wheels
PostPosted: Thu Sep 06, 2001 11:52 am
I tried the steel 13" wheels from a Metro convertible on an '89 GTi and the would not fit. If I recall correctly, the center hole for the hub was too small on the Metro rims, and the rear brake calipers would not fit. You might find an alloy rim that would fit, but it would be trial and error. <p></p><i></i>
PostPosted: Thu Sep 06, 2001 2:12 pm
I tried 13" rims from a turbo and they would not fit over the rear disks. Also the brakes are different. The Turbo has drums on the rear and I believe smaller disks on the front. <p></p><i></i>
PostPosted: Thu Sep 06, 2001 4:34 pm
Iain Paterson posted something about it, it´s possible all you have to do is use the axel grinder in the rim to make the needed clearance, a few mm.<br><br> <p>Oscar Bartol. Madrid (Spain).</p><i></i>
PostPosted: Fri Sep 07, 2001 8:43 am
I don't know if I would start grinding away on "extra" material. I guess if it was just the corner of a caliper or something.... <p>Keep those RPM's high!www.lobase.homestead.com/lobase.html</p><i></i>
PostPosted: Fri Sep 07, 2001 10:39 am
I'll just stay with 14's.<br><br>I was wanting to go with a lighter 13" combo... <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br><br> <p></p><i></i>
PostPosted: Sat Sep 08, 2001 5:26 pm
Exactly... I believe this is what Ian did to get<br>the 13's to fit. Just ground down a wee bit of the<br>corner of the rear calipers to get 'em to fit.<br>It's on his webpage I think.<br><br>Darryl <p></p><i></i>
PostPosted: Sun Sep 09, 2001 6:10 pm
My GTi came with 13" American Racing Alloys that fit over the calipers with what appears to be about 1/8" of clearance.<br><br>When I get a chance this week, I'll pull one to get a model number and to confirm that the calipers have not been modified (they don't look like they have been).<br><br>Bottom line: I'm pretty sure 13" wheels exist that will fit... <p></p><i></i>
PostPosted: Mon Sep 10, 2001 2:55 pm
I was at a garage sale on the weekend and saw a brand new set of aluminum mags for sale. These were EI ???? turbine style mags that were a 13" with a universal bolt pattern. NEVER had a tire or valve installed and in MINT condition. Catch this the old guy was "asking" 20 bucks each!!!!! Someone could probably get all 4 for only 60bucks canadian (40 US)......for light 13" rims.....if anyone is serious (they are in British Columbia) I will bring the guys phone number to work and post it. <p>Keep those RPM's high!www.lobase.homestead.com/lobase.html</p><i></i>
 Post subject: 13" Wheels in Abby
PostPosted: Tue Sep 11, 2001 2:51 am
Hey Tony,<br>Whats the deal with the wheels, I sent you an email with some info. Write back asap. thanks. <p></p><i></i>
 Post subject: Re: 13" Wheels in Abby
PostPosted: Tue Sep 11, 2001 12:20 pm
I run Compomotive 13 inch wheels for competition. I had to grind about 1 mm off the very corners of the caliper retaining brackets. I've just discovered two of the wheels will clear the standard calipers and two won't, (different car), so It's best to check all of them, production tolerance and all that. I have no clearance problems at the rear (disk converted saloon), provided I keep the balance weights external. <p></p><i></i>
PostPosted: Wed Sep 12, 2001 10:23 am
Lobase, please post.<br><br>I want those wheels! <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br> <p></p><i></i>
PostPosted: Wed Sep 12, 2001 11:21 pm
I sent you an email from work but the internet connection is down so it will probably come up tomorrow. i didn't forget about you <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p>Keep those RPM's high!www.lobase.homestead.com/lobase.html</p><i></i>
