It is currently Mon Feb 19, 2018 11:55 am
 Post subject: 1.0L + gti brakes ???
PostPosted: Tue Sep 11, 2001 11:25 am
can i fit Gti calipers to my stock cultus 1.0L ?<br>will i need Gti rotors also?<br>i presume lowering springs for Gti will also fit. will they??<br>also are the Gti `s rear brakes drum or disc type ? if they are disc type can i convert mine to discs on the rear? <br>jd. <p></p><i></i>
PostPosted: Tue Sep 11, 2001 7:08 pm
I am not 100% sure about this. I once converted a 3cyl. sprint to a GTi. The change to the GTi front and rear rotors was possible on this car but required all of the brake hardware from the GTi. We changed the master cylinder but I think that the Sprint one would have worked. Yes the GT/GTi does come with rear discs<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Tue Sep 11, 2001 8:22 pm
Senior Swift Guru
it needs discs, wheel bearing hub, calipers, etc. <br><br>On the bright side you can pop the whole unit off from a GTi fairly easily. The two back bolts on the back of the strut, sway bar bolt, and the one that holds the brake assembly to the control arm. Pretty easy if you've got all the parts.<br><br> <p><br><a href="http://www.teamswift.net"><img src="http://members.home.net/2832075173/pics/Swiftafter1c.jpg"></a></img><br>Kyle Jones <b>1989 Suzuki Swift GTi</b><br>Your friendly TeamSwift Op.</p><i></i>
