It is currently Mon Feb 19, 2018 6:34 am
PostPosted: Fri Sep 21, 2001 9:56 am
Any problems replacing the 175/60's with 185/60's on stock wheels?<br> <p></p><i></i>
PostPosted: Fri Sep 21, 2001 10:39 am
I run 185's on my stock rims for the winter. They are a BFGoodrich winter radial T/A mud and snow. I find this is an excellent winter tire and keeps my 10 year old rims looking nice <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br><br>They do pull the tire in a little so it isn't as wide (at the bead) as on say a 6" rim (I believe the stock rims are 5 1/2") <p>Keep those RPM's high!www.lobase.homestead.com/lobase.html</p><i></i>
PostPosted: Fri Sep 21, 2001 2:31 pm
185/60R14 tires are about 1/2 inch larger in diameter than the stock 175/60R14s. That means your car will sit about 1/4 inch higher, and your speedometer/odometer will be about 2 percent off (about 1 mph low for each 50 mph). <p></p><i></i>
PostPosted: Fri Sep 21, 2001 3:48 pm
Thanks guys. Just double checkin to see if they'd fit.<br><br>I want to swap the tires from my delSol on to the GTi and get some new wheels for the delSol. <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br> <p></p><i></i>
PostPosted: Fri Sep 21, 2001 3:49 pm
4x114.3 sure annoys me though.<br><br>I really wish I could have just swapped the entire wheel over.<br> <p></p><i></i>
PostPosted: Fri Sep 21, 2001 4:37 pm
I have some 185/60HR14 D60A2 tires on stock steelies. The speedo seems to match those radar/speed display though.<br><br>I will check with my GPS unit to see how off is the speedo. <p></p><i></i>
PostPosted: Sun Sep 30, 2001 2:39 pm
I just had BFG Comp T/A HR4 tires put on in that size, previously had winter tires in the same size on. I guess I should be doing it the other way around this time of year <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> Havn't had any problems, the car is also lowered a bit. <p></p><i></i>
PostPosted: Wed Oct 03, 2001 1:28 am
IVe got 185/60/14 on my 89 GTi and they work just right <p></p><i></i>
PostPosted: Fri Nov 16, 2001 9:00 am
Damn, i wish i'd known that you could do that, just got a new set of 175/60R14 Goodyears <!--EZCODE EMOTICON START :( --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":("><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Sat Nov 17, 2001 2:48 am
4x114.3 (bigger four) sure sucks. I couldn't find anything cheaper that can fit the Gt. I just don't understand why Suzuki did that. On the newer Suzuki, they change to smaller four pattern as almost every smaller FWD importer does. Usually, smaller car uses smaller four bolt pattern when the larger RWD import uses bigger four. So, it ends up with either the offset fit but the smaller four bolt pattern or the bigger four bolt pattern with deep offset. Conclusion, nothing fits Gt unless you really pay for it either buy it new or get something with univeral bolt pattern! Too bad =( <p></p><i></i>
 Post subject: need stock wheels!
PostPosted: Sat Feb 09, 2002 12:38 am
hey! anyone out there with their stock rims that can get rid of them. I REALLY,REALLY, need some stock rimsand tires or whatever can fit. I'll pay cash! <p></p><i></i>
 Post subject: Re: need stock wheels!
PostPosted: Mon Feb 11, 2002 11:35 am
I may have a spare set available. Where are you located? I'm in Minnesota. <p></p><i></i>
