It is currently Sat Oct 21, 2017 11:01 pm
 Post subject: Camber adjustment
PostPosted: Fri Dec 07, 2001 8:43 am
Hi,<br><br>Does anybody is using some type of camber adjustment kit? Wish one? how much was it?<br><br>I know whiteline has camber and castor kits but there should be someone in the US that makes them.<br><br>Thanks,<br><br>Bolivar <p></p><i></i>
 Post subject: Re: Camber adjustment
PostPosted: Sat Dec 08, 2001 2:04 pm
Hi Bolivar,<br>I use Aligncraft camber bolts, I think they are manufactured by a company called Ingalls.<br><!--EZCODE AUTOLINK START--><a href="http://www.alingcraft.com">www.alingcraft.com</a><!--EZCODE AUTOLINK END--><br>It took me two years to bend one, so they seem to be OK. They allow up to -1 degree negative(or 1 deg positive, not that anyone would), but I redrilled the front struts using these as guides and I can no go from 0 to -2.25 ged negative.<br>I think the prices about C$35-40 canadian <br><br>Iain <p></p><i></i>
PostPosted: Mon Dec 10, 2001 8:00 am
Iain,<br><br>The link doesn't work. Any other link?<br><br>Bolivar <p></p><i></i>
PostPosted: Mon Dec 10, 2001 9:12 pm
<!--EZCODE AUTOLINK START--><a href="http://www.aligncraft.com/cars/suzuki.html">www.aligncraft.com/cars/suzuki.html</a><!--EZCODE AUTOLINK END--><br><br>You will then follow the link 'applications'<br>and will then notice that the suzuki application<br>link is misspelled as 'susuki' and the link does<br>not work... try this instead:<br><br><!--EZCODE AUTOLINK START--><a href="http://www.aligncraft.com/cars/suzuki.html">www.aligncraft.com/cars/suzuki.html</a><!--EZCODE AUTOLINK END--><br><br>Oh wow... they have a camber kit for the rear<br>as well as the fronts! Not! The 3541 kit is for<br>the front struts only.<br><br>Good luck.<br><br>Darryl <p></p><i></i>
PostPosted: Tue Dec 11, 2001 8:37 am
The part number for the suzuki is 12mm bolts but I notice that the swift is 17mm, well thats the tool I use on my car. <br><br>Has anyone had this camber bolts on a 96 GTi?<br><br>Bolivar <p></p><i></i>
PostPosted: Tue Dec 11, 2001 8:50 pm
it´s the same for mk2 and mk3, no difference between them,<br>i used them when i had the problem with the chasis alignment that i told you wit hmy old mk2, but i didn´t managed to take it from -2º to 0º, it was a lot, the screws seems good, but you have to take care with them when thigtening them, they use to brake if you use them in a bad way, Iain has more experience with them, the strut is the same, they are commonly use on vitaras over here to avoid, wrong camber at raids. <p>Oscar Bartol. Madrid (Spain).</p><i></i>
PostPosted: Wed Dec 12, 2001 9:47 am
This means that they are 12mm bolts right? Do you have the part number?<br><br>Bolivar <p></p><i></i>
PostPosted: Wed Dec 12, 2001 1:26 pm
i have some front eccentric camber bolts ... set to -1.5 deg<br>i forgot the manufacturer but these were a standard 12 mm bolt and on the box it listed a few different cars that it fit<br><br>i bought them from a nissan 240sx guy he said they were the same for the swift - they fit perfectly <p><P><A HREF="http://www3.telus.net/tc2468/">Tom's Webpage</A></P><P><A HREF="http://www3.bc.sympatico.ca/tc2468/swiftgti/ssgti90/ssgti90_pics.html"><IMG SRC="http://www3.bc.sympatico.ca/tc2468/small2.gif" BORDER=0 WIDTH=60 HEIGHT=45></A></P></BODY></HTML></p><i></i>
PostPosted: Wed Dec 12, 2001 2:33 pm
no i don´t, es algo universal no requiere nada especial.<br><br> <p>Oscar Bartol. Madrid (Spain).</p><i></i>
PostPosted: Wed Dec 12, 2001 2:45 pm
Does some one know the part number of the front and rear camber kits from Whiteline? I know that castor kit is KCA302.<br><br>Bolivar <p></p><i></i>
PostPosted: Wed Dec 12, 2001 7:51 pm
The adj. bolt kit is KCA412 <p></p><i></i>
PostPosted: Thu Dec 13, 2001 8:54 am
Does are for front camber adjustment. How about the rear? How can the rear camber be adjust?<br><br>Bolivar <p></p><i></i>
PostPosted: Thu Dec 13, 2001 7:14 pm
Whiteline DOES NOT make a camber kit for the<br>rear of the Swift.<br>I saw this from a Whiteline tech on Whiteline's<br>tech message board. Lemme see if I can find it...<br><br>Go to the following link and do a search of the<br>archive for 'swift'... you'll find it...<br><br><!--EZCODE AUTOLINK START--><a href="http://groups.yahoo.com/group/whiteline/">groups.yahoo.com/group/whiteline/</a><!--EZCODE AUTOLINK END--><br><br>Darryl <p></p><i></i>
PostPosted: Fri Dec 14, 2001 11:51 pm
Is there anyone out there who has managed to find a way of putting camber on to the back of a late model swift?<br> Cheers Dave <p></p><i></i>
