http://www.teamswift.net/
 Tire Sizing - STICKY TOPIC
http://www.teamswift.net/viewtopic.php?f=10&t=1220
Page 2 of 5
Author:  rubberburner [ Mon Apr 28, 2003 12:46 pm ]
Post subject:  Re: aftermarket wheel weights
Mine is lowered 2" (apex),with 16"7J 195-40,and it NEVER rubbed !<br>It's even 0.4% smaller than the original diameter...(14"175-60)<br><br><!--EZCODE IMAGE START--><img src="http://images.cardomain.com/member_img_b/279000-279999/279392_57_full.jpg" style="border:0;"/><!--EZCODE IMAGE END--><br> <p><!--EZCODE IMAGE START--><img src="http://rubberburner.streetracing.org/images/banner10.jpg"/><!--EZCODE IMAGE END--></p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=rubberburner>rubberburner</A> at: 4/28/03 12:53:02 pm<br></i>
Author:  Zyklon [ Mon May 05, 2003 12:37 am ]
Post subject:  215/40 16" wheels
Recently I wear my tires on 16" wheels. Size 215/40 is freakin' wide, too wide. The car noticeable slows down. I don't recommend anyone such tires, rear wheels rub sometimes, front wheels fit perfectly (stock suspension). My wheels (RONAL 28 ) are very heavy. With all this disadvantages I must say one thing: Suzi is looking awesome <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>You can see it here: <!--EZCODE AUTOLINK START--><a href="http://www.kret.za.net">www.kret.za.net</a><!--EZCODE AUTOLINK END--> <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=zyklon@teamswift>Zyklon</A> at: 5/5/03 12:40:07 am<br></i>
Author:  Murr [ Thu May 15, 2003 11:18 pm ]
Post subject:  Re: 215/40 16" wheels
i have run many different sizes of tires.<br><br>but here are my street rims<br>with dunlops 205 40 16's<br><!--EZCODE AUTOLINK START--><a href="http://groups.msn.com/holyshift/suzukiswiftgtsuspensionmods.msnw?action=ShowPhoto&PhotoID=313">groups.msn.com/holyshift/...hotoID=313</a><!--EZCODE AUTOLINK END--><br>its not lowered much but no rubbing. the rear lip is rolled but absolutly no rubbing.<br><br>Murr<br> <p>MURR<br>Racing... Because other sports require only 1 ball</p><i></i>
Author:  nuformz [ Tue May 20, 2003 12:56 pm ]
Post subject:  Toyo Tires Guys...Toyo Proxes T1-S
hi ppl, i am right now rollin on Toyo Proxes T1-S 195/45/r15 and boy do they hold, Tread Ware 280 Traction AA Temperture A. you can chk them out at <!--EZCODE LINK START--><a href="http://www.toyo.com" target="top">www.toyo.com</a><!--EZCODE LINK END--> <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=nuformz>nuformz</A> at: 5/20/03 1:01:02 pm<br></i>
Author:  n1tr0 [ Mon May 26, 2003 10:23 pm ]
Post subject:  kumho supras =)
i just put on a pair of kumho supra ecsta 712's on the front before i bombed out to calgary & back the other weekend .. hit all sorts of weather from dry mountain highway to sleet/hail/wetsnow .. they really stick ! =) really cheap to. i paid $92cdn each for 185/55/r14 .. according to my gps the speedo is only out (reads high) by about 3km/hr @ 140km/hr.<br>the whole trip was about 2400km's in one long weekend. & i've noticed a lot less tire spin compared to my semi-budget 185/60/r14's i was running before.<br> <p></p><i></i>
Author:  vegz07 [ Wed Jul 02, 2003 1:43 am ]
Post subject:  toyo tyres
hi guys, my setup is toyo T1-S 195/50/15 for front n toyo R1-R 195/55/15 for the rear. super grippy cornering n very stable n not forgetting very comfortable too.especially going over bumpy roads no feeling at all.<br>toyo T1-s very good tyres for wet n dry. toyo R1-R much much grippier as it's a semislick tyre. stick to the ground like glue. only downside using such sizes of tyre is that gti looks like a jeep.hahaha <p></p><i></i>
Author:  western gti [ Wed Jul 30, 2003 8:39 pm ]
Post subject:  TYRE SIZE
MY CAR IS LOWERED ON EIBACH SPRINGS WITH KONI STRUTS . IT USED TO RUB SLIGHTLY WHEN I HAD ON 185/60/14 TYRES. I HAVE SINCE PUT ON 195/50/15 TYRES BUT I HAVE NOW ROLLED THE FENDER INNER LIPS. NOW THE RUBBIN IS GONE. THE 15 INCH RIM AND TYRE COMBO SLOWS THE CAR DOWN THOUGH SO IM GOING BACK TO 14" OR 13" FOR COMPETITION. I FIND THE KUMHO TYRE TO BE TOO HARD IN COMPOUND AND SOFT FOR POTHOLES. I AM GOING TO BE TRYING DUNLOPS OR SUMITOMOS IN 195/50/15 FOR STREET DUTY <p></p><i></i>
Author:  Descent-Boy [ Fri Jan 16, 2004 9:06 pm ]
I just put 16x7" TSW Ribs rims on my '93 Geo Metro, with 215/40/16 Nitto tires, the offset is 40mm. I wanted to get it lowered hella, so the wheels would be tucked under the fender, but it appears that they will hit. The rim and tires extend out all the way to the fender. I've seen other Swifts with the same size tire that are tucked under. How do I do it?
Dave
Author:  yeahright [ Thu Apr 08, 2004 4:11 pm ]
So right now are you having any troubles with your 16x7's?
because im thinking of buying some Enkei RS6 wheels and there 16x7 with 38 offset....
Author:  Descent-Boy [ Fri Apr 09, 2004 12:29 am ]
I noticed a bit of rubbing when I crank the steering wheel all the way to one side. I'd recommend staying in the +40 thru +45 mm offset when running with 16x7 or 17x7 wheels. I've since put them on my swift GT, but now I'm going to go back to the stock 14 steelies. Next time I buy rims, I'll rememeber to buy LIGHT ones :lol:
Dave
Author:  CMA [ Sat Jul 03, 2004 5:36 pm ]
i am curious... do swift's tires (with rims) is make big difference? handle and acceleration?
if so then
what if i want best handle then what size of tire is it?
what if i want best acceleration (speed) then what size of tire is it?
i am only interesting in performance than look ( in my opinion 8))
Author:  Lihtan [ Sun Jul 04, 2004 9:08 am ]
The size and weight of your wheels are the biggest factors determining wheel performance (other than tire traction). Heavy wheels add more rotating weight, taking the car longer to accellerate and brake. Larger sized wheels also raise the gearing of the transmission, again slowing accelleration.
Author:  CMA [ Sun Jul 04, 2004 1:26 pm ]
so recommend tires are 14"?
my car's original tire size is 145/80R12 :shock:
one question more, do brands make difference?
i personally like yokohama (tire) and rage or maybe other brand(rim)
Author:  Ouird [ Sun Mar 13, 2005 6:17 pm ]
this is a good site to check what size tires fit on ur car, this is what i used.
http://www.1010tires.com/tiresizecalculator.asp
really simple, and when your done, you can check for tires as well. dunno if yous guys have ever used this site, but its pretty common where im from.
Author:  CJDavE [ Thu Jun 09, 2005 7:29 pm ]
Looking around at http://www.1010tires.com, I've noticed a set of 15" steel rims that have the right bolt pattern, but an odd offset of +32mm. That'll surely help the rubbing issues someone might have with wider 15" tires, but I'm worried that they'd push the tires a bit too far outside the wheel arches. I can get 45mm offset 15" steelies from Walmart as well... but I'd be worried about rubbing on turns, for sure.
Any thoughts on the arch clearance issue with the 32mm offset wheels?
Chris
Author:  CJDavE [ Sun Jun 12, 2005 11:31 pm ]
Sat down with the calculator and a pad of paper and came up with these numbers:
Current 14" steelies (which rub ever so little when the wheels are cranked... keep in mind this is on a 1.0L car without having the hubs swapped to the 'vert or GTi bits):
- +45mm (~1 3/4") offset
- 5.5" wide
Therefore:
- ~1" on the outside of the rim
- ~4 1/2" on the inside of the rim
1010tire.com 15" steelies (the rims in question):
- +32mm (~1 1/4") offset
- 6" wide
Therefore:
- ~1 3/4" on the outside of the rim
- ~4 1/4" on the inside of the rim
Sooooo:
The difference on the inside of the rim is ~-1/4", which would definitely solve the rubbing issues when moving to the 15" +32mm steelies, assuming that the tire cross-section width remains the same.
The edge of the 15" rim will move ~+3/4" further out from the current 14" steelie's position. This may/may not be a problem. I'd have to go out there with a measuring tape to see if that'll clear, but it seems to me that there's 3/4" to spare.
Can anyone see a problem with my maths? If not, I might've just answered my own question. :)
Chris
Author:  mac [ Fri Jul 29, 2005 6:17 pm ]
anyone tried both 195-45-15's and 195-50-15's? i'm wondering if the 45 profile helps acceleration siginicantly or not
Author:  HiTempguy [ Mon Aug 22, 2005 9:35 pm ]
Just for future reference when people visit this site in 10 years :lol: , IMO 205/50R14's are a godly size to use while racing.
http://teamswift.net/viewtopic.php?t=17004
Author:  MatLax [ Mon Apr 17, 2006 10:46 am ]
Using 1010tires I had some fun with the numbers, using my stock (155-80-r13) tires as a reference, I think I will switch to 195-70-r14. If the web stie works well, the tires fit 5.5 to 7'' wheels (stock tires fit 4.5 to 5.5''), I my car should read 0.083% too fast (wich means that I don't really have to care about that) and it shouldn't affect mpg a lot since the tire would be the same size as the stock one... am I right or should I go back to school?
edit: also, I had found tires before that were 15'' and would make the car read 60.2 mph while stock would read 60... but I can't remember what were the exact specs for the tires...
Author:  CJDavE [ Mon Apr 17, 2006 11:03 am ]
That's always handy. Or you can go down a size, to a 65 or 60 profile tire to gain a bit of extra torque and better handling. Plus you'll never be pulled over by the cops if you keep to the speed limit that your speedo reads since you'll actually be going 1 or 2% under the speed limit. :D
Chris
Author:  MatLax [ Mon Apr 17, 2006 11:16 am ]
yeah, but I just don't want to f*ck with the odometer ;)
but logically speaking, if I switch to 14'' rims that weight less than the stock rims, that I have smaller tires (since they're the same overall size, but the rim in the middle is taller, wich means there's less tire and more rim, if you understand what I mean...) wouldn't that mean that overall it would weight less, giving a bit more power to my car?
Author:  CJDavE [ Mon Apr 17, 2006 12:06 pm ]
As long as the whole tire+rim combo weighs less than the stock combo. Plus the more weight to the outside of the diameter or the rotating assembly affects the energy required to move the tire more than in the inside. So a tire that weighs more and a rim that weighs less, even if the combination is lighter, might end up being less beneficial.
Likely the 14" tire with the shorter sidewall (than stock) will be a better choice and will weigh less anyway. Unless you get something that's bulletproof and has a million plys of steel. ;)
Chris
Author:  Woodie [ Mon Apr 17, 2006 6:52 pm ]
Something is WAY off here, 185/60-14 is the same diameter as your stock tires, 195/70-14 would be much larger.
Page 2 of 5 All times are UTC - 5 hours
http://www.phpbb.com/
