It is currently Fri Jan 19, 2018 4:22 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Drilled shocks
PostPosted: Fri Mar 16, 2012 9:55 am
I used Belray fork oil.
I use this page for viscosity reference when I'm doing suspension work on my bikes.
http://www.peterverdone.com/archive/lowspeed.htm
PostPosted: Fri Mar 16, 2012 10:33 am
Thanks Suprf1y!
That reference is up in the sticky, so I apologize for not looking closely enough at it to really see what it meant. Sometimes I have to be told where to look again. RMProb used Belray 25wt with cut springs with some success too, so I guess I am looking at something in the 70's - 90's range for cST@40c--maybe on the higher end of that given that I am cutting Mk4 springs rather than the stock springs and going for about an inch drop.
I am actually on the fence about which springs to cut in the front--I kind of don't want to screw up the stock Mk3 ones, but I also want to keep the car as softly sprung as possible while still improving transitions and loosening up the balance.
I can't believe I just learned a whole new unit of measure that I'd never heard of before.
PostPosted: Fri Mar 16, 2012 2:45 pm
I forgot that I had posted that. Go with the Mk4's, you won't be disappointed in the ride.
