It is currently Mon Feb 19, 2018 12:56 am
PostPosted: Thu Oct 16, 2008 4:06 am
Ok guys, first post here. I m doing a little (re)search for a friend who's obsessed with fitting BIG brake rotors on his 92 GTi. After some searches in here, I couldn't find something suitable, as his plan is "as close to the rim as possible, as nice looking as possible, I don't care about breaking performance". Now I know this is completely messed up :lol: ,but hey...what can you do? So I searched some more and something about Silvia calipers pops up. That could be interesting, because of the plethora of aftermarket options for this car. But what calipers and what adapters for the calipers should we go for? He's got 15" rims on, for the time being. Anyone with experience on this or a similar setup? Any input and alternatives, welcome.
(Sorry for the bad English :oops: )
(edit)...on further inspection, I can't seem to find a single silvia model that used the 4x114 pattern...
Now I'm really confused...
PostPosted: Thu Oct 16, 2008 4:43 pm
you want big brakes?
http://www.redlinegti.com/forum/viewtopic.php?f=4&t=35551
Honda civic 12 inch rotor kit with the lancer disk hat :wink:
PostPosted: Thu Oct 16, 2008 5:12 pm
Nissan SE-R Spec-V 2006 oem big brake Brembo kit rotors
rear disc
The Nissan rotor is heighter than the Swift rotor, but it fit the rear hub without any rubbing
Swift OE disc diameter
Nissan brembo disc diameter
Front disc
Same height
Overall view :twisted: :twisted:
I will use aftermarket caliper
Wilwood Dynapro 4 pot for front
Wilwood Dynapro 2 pot for rear
I have not received the caliper yet but I wish they will arrived during next week
There is some picture of the front rotor fitment into my 16inch wheel..
The overall radius of the kit is 6''7/8, that means that it will remain 1/8'' between the caliper and the inner wheel.
Suzimaniac.
SX4 JLX 07 (winter beater)
Swift GT-T 93 (summer beater)
PostPosted: Fri Oct 17, 2008 3:34 am
Thanks guys, much info to look through. That Nissan SE-R setup looks really nice.
PostPosted: Fri Oct 17, 2008 9:18 am
thats hot
the lolcar family
PostPosted: Sun Oct 19, 2008 11:50 pm
There is a setup of a friend
11'' Nissan Sentra SE-R 2004 front rotor + Bicknell 4 pot caliper + custom bracket
***15 inch wheel minimum***
Suzimaniac.
PostPosted: Mon Oct 20, 2008 9:35 pm
hey that's my idea of picture! =)
I just had an idea staring at the other side of the wheel. Martin's Bicknell calipers with SOHC hubs, and a GT rotor, to fit on a 14" wheel. or maybe your type-R calipers? what do you think? :ez_wink:
do you have a GS hub that you could test fit your calipers on?
Suzuki Gold Master Tech
PostPosted: Tue Oct 21, 2008 5:47 am
no, sorry.....no GS for me.....and the Type-R caliper do not fit 14'' anymore.
Solution...
Garndi wrote:
Jonny's Wilwood conversion :D
HONDA INTEGRA 1.8
INTEGRA 1.8 TypeR 16v VTEC DC. 10/95
Fr Di 952010 V 4 262 51 64 20
Diameter: 262
Thickness: 21
Min Thk: 20
S/V: V
HT: 51
Bore: 64
Studs: 4
http://domain421029.sites.fasthosts.com/
I dont want to sell the brackets..... I dont sell brakes not something I mess with on other peoples cars!.
I have however sent Sam the DXF file for the bracket (use at your own risk), hopefully he will be able to host the file and you guys can get it made, should be cheap as all the hard work has been done :wink: .
These are 4 pot dust sealed Midilites drop-forged billet....etc
I have the part number BU -120 - 7376.
These were brought from......>
http://www.rallydesign.co.uk/product_in ... ts_id=8317
You will also need to adapt the caliper to the brake line.
or this setup.....that fit 13'' wheel :blackeye: ....don't know more about this setup
john49 wrote:
Just got my new 13 x 8 rims today, These are 4kg's a rim :shock:
They fit just perfect over the 4 pot calipers
Suzimaniac.
PostPosted: Tue Oct 21, 2008 3:09 pm
Another setup.......with honda caliper bracket from Wilwood
4 banger wrote:
calipers are universal fit but the bracket to mount the caliper is from civic/prelude...rotors are 292mm....
......RX7 caliper on unknow rotor (I think they are 11'')
4 banger wrote:
RX7 FC3s 4 Pot brakes
I previously made some research about wilwood conversion and there my result
suzimaniac wrote:
There are some spec that you need to know before searching any part that may fit GTi hub.
- car - year -rotor diameter (mm) - hub diameter(mm) - rotor hat height(mm)- boltpattern
- Suzuki Swift GT - 1989 to 1994 - 250mm - 60,1mm - 50mm- 4x114,3mm
And there are the spec of other car
- Honda Accord 4 cyl - 1990 to 2002 - 259,8mm - 64,10mm - 47mm
- Acura CL 2,3l - 1998 to 1999 - 259,8mm - 64,15mm - 47mm
- Honda Prelude Si - 1992 to 1996 - 262mm - 64,1mm - 47,1mm
- Acura Legend - 1986 - 262mm - ? - 51,2mm
11inchs rotor (you need a custom bracket if you want those rotor to fit the caliper)
- Honda Prelude Vtech - 1992 to 1996 - 282mm - 64,1mm - 47,1mm
- Nissan Altima - 1993 to 2001 - 282mm - 66,1mm - 49,2mm
- Acura Legend coupé - 1987 - 282mm- ? - 51,2mm
After that I think that you can start your search
There is a link to download the wilwood catalog: http://www.4shared.com/file/61890045/c4a751d1/2008_Tech_Catalog.html
Honda caliper are direct bolt-on on GTI hub
so we can use the bracket(250-8642) that come in the 11'' honda kit(140-8695)
PDF;http://www.4shared.com/file/61890589/676f901d/140-8695.html
or the bracket (250-6289) that come with the 12,19'' honda kit(140-6163)
PDF;http://www.4shared.com/file/61890047/2aa930fd/140-6163.html
2002 MITSUBISHI LANCER with 4x114,3mm of bolt pattern have front rotor height of 47mm so we can use the Hat(170-6996) from the wilwood kit(140-7015) PDF;http://www.4shared.com/file/61890449/ca18b526/140-7015.html
Note: if you use the lancer hat, that have a bolt circle of 8x7,00'' you will have to use 12,19'' rotor(160-5843) because 11'' rotor(160-5840) have a bolt circle of 6x6,25''. If you want to use 11'' rotor, you need custom made hat or use one piece rotor from an other car that came with 11'' from OEM.
There is something to know about the honda caliper bracket, is that they do not have the same dimension if you take a kit that is disgned to suit the Honda 240mmOE hub or the Honda 262mmOE hub. As you can see in the document follow, there is two different part number for the Honda big brake(http://www.4shared.com/file/61890384/1d ... _list.html)There is a email reply from Wilwood:
Hi Gabriel, Thank you for your interest in Wilwood products. The difference in the brackets has to do with the brake rotor size. The 250-6290 is for the 240mm rotor & the 250-6289 is for the 262mm rotor. These brackets are identical except the is 1 3/16" from the bracket mounting holes to the caliper mounting holes & the 250-6289 is 1 11/16" from the bracket mounting holes to the caliper mounting holes. These measurments are from the bolt hole center to center. I hope this helps you out. If you have any other questions please feel free to email me anytime. Hope you have a great day.
Thanks, Jeff Williams
----- Original Message -----
To: customerreply@wilwood.com
Subject: bracket dimension
Hello, I have search and found nothing. Can you send me a pdf file or a cad file of those caliper bracket (250-6290 and 250-6289). I want to know what is the difference between those two brackets. Is the caliper will be mounted further on a bracket than the other. One bracket is designed for a kit for 240mm oe disc and the other is designed for 262 oe disc.
Thanks you
Gabriel
To this, I know that my custom bracket have approximatly 1 11/16" (+- 1/8) from the bracket mounting holes to the caliper mounting holes, that maybe means that the 250-6290 bracket is a bolt on issue form the 12'' wilwood caliper conversion.
Suzimaniac.
PostPosted: Thu Feb 12, 2009 12:53 am
some helpful (hopefully) info.
as far as nissans go, check into the 200sx(s12 or gazelle in europe) i have an 84 as my "baby" bolt patern is 4x114 i dont know the rotor measurments off the top of my head but i can find them for you if you want me to. also they are kinda rare but the s110 has disks all the way around and they are 4x114 as well. and there are "longer than stock" wheel studs available for the s12. hope this helps
PostPosted: Sun Feb 15, 2009 1:36 pm
actually thought I'd throw in that the 4 piston calipers from a 300zx are supposed to fit first and second gen altimas with a rim size upgrade, probably useless to us, as we can't really fit 17's on these things :P
PostPosted: Sun Feb 15, 2009 3:35 pm
this is cool. my 400 hp metro swap is gonna need some brakes and I'm thinking 15 or 16" wheels. I'm building that one this fall
the lolcar family
PostPosted: Fri Mar 13, 2009 9:27 pm
Some update on the wilwood setup.....don't have pisture of the rear bracket.
As you can see, the rotor are way too big for the caliper...or :mrgreen: the caliper are way to small for the rotor
Doesn't matter, I love the way it look.
Rear bracket in 3d
Suzimaniac.
PostPosted: Thu Mar 26, 2009 10:55 am
Some photos of the rear installation
And the front
Don't freak-up the nut on the hub bolt are there because my bolt was too long :wink:
Suzimaniac.
PostPosted: Thu Mar 26, 2009 10:57 am
A setup of a friend of mine
11'' Nissan Altima Rotor
15'' wheel
Bicknell race caliper
Serious GT wrote:
Some news
Suzimaniac.
PostPosted: Thu Mar 26, 2009 12:21 pm
what wheel is this?
HANSTECH
member of team
PostPosted: Thu Mar 26, 2009 3:57 pm
my disc that i use are altima 1993 to 2001 the aluminum plat tha i use is machine 0.030 on the gallapers side to center it to the disc .sorri for my anglech in Quedecer hihi thank Suzimaniac for the photo
PostPosted: Thu Mar 26, 2009 5:51 pm
COOKIEMNSTR wrote:
what wheel is this?
13X8 wheels :shock:
Redlinegti post:
http://www.redlinegti.com/forum/viewtopic.php?f=4&t=34964
Suzimaniac.
PostPosted: Thu Apr 02, 2009 9:09 am
Out of topic but could u tell us brand ond offset of those beutiful rims....
Thanks
89 Suzuki Swift Turbo
03 Infiniti G35 sedan
PostPosted: Fri Apr 03, 2009 9:57 am
Compomotive CXR's
http://www.comp.co.uk/wheels/wheels.asp?range=CXR_0001
ImageET 13.138 at 120.2mph
PostPosted: Wed Feb 17, 2016 8:30 am
Hi, first time post.
I like the Nissan SE-R Spec-V 2006 oem big brake Brembo kit rotors
with Wilwood calipers.
Wilwood Dynapro 4 pot for front &
Wilwood Dynapro 2 pot for rear.
I'm guessing you had to make a custom bracket,
will you be posting the details of the bracket.
I'd like to use your setup for my own Swift Gti.
Thank you
