It is currently Thu Oct 19, 2017 12:10 pm
 Post subject: Another offset question!
PostPosted: Fri Nov 05, 2010 3:59 pm
Im wondering how the width of a wheel can effect the offset of it in relation to the car, if at all?
What i mean is this-
Lets say we have a 6" wide wheel with a +40 offset. This wheel sits exactly flush with the wheel arch.
If we then replace this wheel with a 7" wide wheel but still with a +40 offset where does the extra inch of width go?
Does the wheel still sit flush with the arch, so look exactly the same visualy, with the whole extra inch going inside toward the centre of the car?
Or, is the extra inch shared with half an inch going inside and half an inch going outside, thus making the wheel stick out a little more?
Thanks fellas :D
INCREASE THE PEACE
PostPosted: Fri Nov 05, 2010 6:02 pm
Offset is measured from the center of the wheel, so an inch wider means half an inch on the inside and half an inch on the outside :D
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
PostPosted: Fri Nov 05, 2010 7:07 pm
I cant remember the offset on my wheels but they are a 7" rim, take a look in my album, they are not flush with the arch though 8)
93 swift g10a 5dr
EAT SLEEP SUZUKI
PostPosted: Sat Nov 06, 2010 6:39 am
Peenutzz - Thats what i was hoping. Means a 7" wide wheel will look wider then a 6" with the same offset :D
Harry - Thanks but without the offset it doesent really help me. :D
INCREASE THE PEACE
cron
