It is currently Wed Oct 18, 2017 3:28 pm
PostPosted: Tue Sep 01, 2009 6:29 am
I currently have a coilover setup on yellow Konis:
The problem with the setup is lack of suspension play at the desired ride height.
I was looking at Koni (http://www.koniracing.com/8611.cfm) and Bilstein inserts (http://ryanizer.blogspot.com/2008/07/bi ... -s14s.html), and currently leaning towards Bilstein (shorter body and possibly cheaper).
Bilstein R36-5022-H0 inserts from the top link would not work, I would have to machine my sleeves too thin to get them in.
Do you know of any thinner Bilstein inserts of the same body length or shorter?
Thanks!
Bye,
Tom
PostPosted: Tue Sep 08, 2009 9:35 am
Made some progress (c/p-ed from http://driftninjaz.com/blogthis/?p=7 ):
Here is a short breakdown of the bilstein numbering system
First letter -
B Shock absorber
P Cartridge
R Reconditioning set
S Sports kit
V Front/rear strut
Second letter – generally only on newer units
E Mono-tube system
M Manually adjustable
N Twin-tube system
If no second letter, first two numbers are the working piston size in mm-
22 -30 -36 -46 -60 -32 are the most common
Also found this insert catalog:
E4-WM5-Y189A01.PDF [62.04 KIB]
Downloaded 798 times
Which gives me some part numbers (not all are available) and the ODs, and some other numers :huh: (maybe the cutting / fitting measures as in page 3 of http://www.allshocks.com/instructions/R36-5022-H0%20instructions.pdf ???) .
Well, on to some more digging.
EDIT: the 'A' dimension in the catalog is not the OD of the insert, but the length on which to cut the original shock (as in the above PDF instructions) :oops:
PostPosted: Fri Sep 11, 2009 8:45 pm
Thanks for sharing those information with us, this will be helpfull.
Suzimaniac.
SX4 JLX 07 (winter beater)
Swift GT-T 93 (summer beater)
PostPosted: Fri Jan 28, 2011 3:43 am
please explain what your "desired ride height" is... i assume its quite low. i was hopeing to run almost the same setup at a very low height so any extra info would be nice
PostPosted: Fri Jan 28, 2011 5:04 am
Holy dead post Dattman :huh:
Measure between the center of your rim and the highest point of your front guard/fender, if that is less than 330mm then that is about as low as you can go on stock struts/koni sports, the shaft will need to be shortened or buy a shock/damper with a shorter body, ie koni 8611-1256 and get it installed into a strut, I think Murr used a VW golf mk1's strut housing.
Beware once you get get lower than about 310mm from centre of wheel to guard you will start to get bumpsteer and excessive camber change so there is little benefit to going much lower unless you can engineer out those issues.
PostPosted: Fri Jan 28, 2011 2:53 pm
What dattman said x2.
You would end up having to make spacers for where the lower control arms attach to the spindle to fix your negative camber gain as the suspension compresses, as well as either moving the rack an pinion up in the body or making spacers for where the tie rods attach to the steering knuckle till the tie rod is parallel to the lower control arm. It's some work, but it is the only way to have a very low car and not be plagued by handling problems(assuming you started off with another, shorter body strut housing).
PostPosted: Fri Jan 28, 2011 6:09 pm
Understood. Thanks for the replys. I'm aware of the bump steer issues as I've got an s13 on coilovers which sees simular issues.
PostPosted: Fri Jan 28, 2011 11:39 pm
But but the Ricer gods demand I drag the the floor on the pavement and think it's hot shit for suspension!
:cry:
hehehe.... :twisted:
My cars:
PostPosted: Sat Jan 29, 2011 1:47 am
its all prefrence bud. thanks for the weak flame. saskamchewawn=ricer hub btw. take a look around. you couldnt put on a hill climb if you wanted too
PostPosted: Sat Jan 29, 2011 1:36 pm
I know, and I just chuckle when I see these guys have to go 5km/h max over a speed bump or they hit a pothole and the whole car starts a dancing.
Meh... I learned how to drive while I lived in Kelowna for a few years, so really, I know all about the pro's and the con's to both sides. In a war of weak burns, your's is winning though... :wink:
My cars:
cron
