It is currently Tue Jun 18, 2013 6:04 pm
 Post subject: 1985 mk1 stability
PostPosted: Sun Dec 12, 2010 11:35 am
i was looking to upgrade the stability of my forsa and dont know were to start i was thinking maybe some shok absorber, spring, swaybar
but here comes my other question were can i buy these online??? were i come from there is no way to find these parts
thanks everyone
suzuki forsa 1985 (SA310)
g13bb swap
GTi flywheel
clutchnet 3 solid puck clutch
clutchnet red pressure plate
honda short shifter> back to stock shifter
short ram intake
baleno 1.6 ecu
custom header with 2" exhaust
GTi front hub and calipers swap
soon mk1 GTi exterior coversion
 Post subject: Re: 1985 mk1 stability
PostPosted: Tue Dec 21, 2010 8:25 pm
since no one have any ideas.....how about this sway bar what you guys think will it fit my 85 mk1?
http://suzukird1.netfirms.com//641pro/c ... 61e35e9e55
g13bb swap
GTi flywheel
short ram intake
baleno 1.6 ecu
PostPosted: Wed Dec 22, 2010 5:41 am
Have a read of some of the sticky's in this forum, basically everything suspension wise will be well past their use by date, before you do anything else go and buy 4 brand new kyb gr2/excel shocks, install them and get a wheel alignment, the difference will astound you.
PS, don't buy anything from Suzuki rd, they talked someone I know into buying 450lb front springs, which would be fine if his swift weighed about 2900-3000lbs, honestly those guys are clueless when it comes to suspension and adding a big heavy front sway bar is going to give you even worse understeer, instability has nothing to do with sway bars, thats an alignment issue.
gamefoo21 wrote:
But but the Ricer gods demand I drag the the floor on the pavement and think it's hot shit for suspension!
PostPosted: Wed Dec 22, 2010 8:34 am
thanks man, whats been your experience with the GR2 shock are they worth it?
g13bb swap
GTi flywheel
short ram intake
baleno 1.6 ecu
PostPosted: Wed Dec 22, 2010 1:22 pm
Well I'm a Koni guy so I would always recommend Koni's :mrgreen: but the Kybs are by far the best budget shock around, I have had them on my mk1.
PostPosted: Wed Dec 22, 2010 3:07 pm
GR2's are NLA so your SOL there. I looked everywhere this summer for a set for my 87, nobody can get them anymore.
Scott
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Wed Dec 22, 2010 5:17 pm
AFAIK they are now called excel G's and are still available as of a few months ago.
http://bdmotorsports.net/index.php?cPath=1_40_96
PostPosted: Wed Dec 22, 2010 7:28 pm
nice page there but my 85 mk1 is leaf spring in the back so are the rear shock the same??
i also noticed they got lowering springs, do they fit my 85 mk1?
g13bb swap
GTi flywheel
short ram intake
baleno 1.6 ecu
PostPosted: Wed Dec 22, 2010 9:00 pm
Front springs and shocks are the same, don't know about the back, lowering the leafs is easy, lowering blocks are fairly common.
PostPosted: Thu Dec 23, 2010 7:50 pm
how about the sway bar they got??? i think it fits
g13bb swap
GTi flywheel
short ram intake
baleno 1.6 ecu
PostPosted: Thu Dec 23, 2010 10:22 pm
Front sway bars will be the same between rear leaf spring mk1 models and rear coil sprung mk1 models, however you don't want to fit a bigger front sway bar onto your car, it will only make your car handle worse.
Sway bars are a fine tuning tool to get the right amount of weight transfer from one side of the car to the other during cornering, and it amazes me that people slap on a big front sway bar and then complain about understeer. :roll:
PostPosted: Fri Dec 24, 2010 1:13 pm
oohh ok then no big ol' sway bar it is thanks for the advise
g13bb swap
GTi flywheel
short ram intake
baleno 1.6 ecu
