It is currently Sat Oct 21, 2017 6:13 pm
PostPosted: Thu Oct 20, 2011 7:33 pm
I'm going to put B&G springs with Koni insert in my 90 turbo sprint front strut, problem is the B&G springs size are different than stock; they are too "narrow" to sit on the cup
the B&G springs are for Suzuki Swift Hatchback 1989-1994 (part# 88.1.006)
question is : are swift front strut different than sprint / firefly / metro?
1992 Geo Metro Convertible (with mk2 g10t)
PostPosted: Thu Oct 20, 2011 7:49 pm
Same from 89-01. Only difference being the place where the brake line bracket is located on the strut.
PostPosted: Thu Oct 20, 2011 7:59 pm
that's what I thought, but the B&G springs just too narrow to sit flush on the cup..... it's hard to describe
here's a pic of the B&G springs I found on eBay, they are same as mine.
it's like front and rear both have same "width" compare to this
PostPosted: Thu Oct 20, 2011 8:17 pm
also strut & springs from hatch should be same as convertible right?
PostPosted: Thu Oct 20, 2011 10:41 pm
Yes.
Looks like Mk1 stuff.
Take some measurements and post them up.
PostPosted: Fri Oct 21, 2011 10:41 pm
they do look like mk1 spring, i have b&g's and thought one was weak but turned out to be a bent lower control arm. go to this link http://www.lmperformance.com/contactus/ leave your phone number and stick by the phone. i got a call from them the next morning. did you buy them from Lmperformaqce or another online seller?
1990 swift GL Twincam swap
PostPosted: Sat Oct 22, 2011 10:50 am
I bought them from Import Replacement Parts http://www.importrp.com
label on box do list correct part number
PostPosted: Mon Oct 24, 2011 2:28 pm
does the part numbers on the box match the number on the springs?
PostPosted: Thu Oct 27, 2011 9:31 am
Don't know if this helps but here are my B&G 40mm springs for the swift
Anyone happens to know the spring rate of the B&G springs?
I emailed them direct about a month ago with no reply
PostPosted: Thu Oct 27, 2011 10:41 am
How much did they cost?
I have a mk1 gti and i need some stiff springs.
G13B 1.3L 16v 115hp
PostPosted: Thu Nov 03, 2011 5:30 am
I bought them off of a local not brand new but according to their website it says $299 new
http://www.shopatron.com/products/categ ... 9207.0.0.0
