It is currently Thu Jan 18, 2018 1:40 pm
PostPosted: Mon Nov 21, 2011 3:30 pm
Hi guys, been reading this forum for some time now and this will be the first opportunity to post a question here...
I have a 96 Gti... I am currently using H&R springs all around with Koni shocks... The combo certainly makes a difference with the handling... But I am facing an issue with the rear springs compressing the
moment something or someone is placed in the back of the car... The problem is evident when they are just two persons sitting up front... Besides the odd look with the front in the air all the time, the
shocks are suffering as well since they no longer have 'full' travel when the rear is compressed...
So, options... does anyone know of a brand and model spring I can get (in the US market) for the rears that will reduce the effect of 'sagging'... I know 'comfort' will also go away, but I am prepared to
deal with it... the car is a everyday driver and I am photographer with gear that is occasionally stuff in the back...
Thanks
Alien
PostPosted: Thu Nov 24, 2011 10:29 pm
No one? :(
PostPosted: Fri Nov 25, 2011 11:34 pm
replace with geo metro rear springs
PostPosted: Sat Nov 26, 2011 12:15 am
A friend of mine has the same problem when transporting his mother-in-law in his 3/4 ton suburban :ROFL: :ROFL:
Current stable:
PostPosted: Sun Nov 27, 2011 10:47 am
Are the rates much higher than the H&R's? and they are no options on this of the planet for rears with rates of 400lbs through 500lbs?
i really would like something that retains a similar ride height as the H&R but much stiffer...
Thanks for the response guys... i would appreciate any other..
Alien
PostPosted: Sun Dec 18, 2011 11:33 pm
Havin that front end up alittle higher is helping your handling. Unless you guys wieght 200+ each or have 200lbs of speakers in the trunk. Are they bottoming out?
If there not bottoming out change the rubber donuts on the rear springs with thicker poly ones.
PostPosted: Mon Dec 19, 2011 2:39 pm
You can also get USDM MK4 rear springs, and cut them. They start life out longer than a MK2/3 spring, so by the time you cut them to give the ride height the H&R's are giving you, they should be substantially less squat prone.
PostPosted: Thu May 02, 2013 9:10 am
Hmmm... wow... never got a notification for this response... Thanks, I will certainly look into this...
Alien
PostPosted: Mon May 06, 2013 8:08 am
i´m in a process of replacing my sedan rears, wich is using gti cutted springs, to the fronts of kia sportage, wire diameter 14, 5 cm , vs the gti wire 13,5, and besides they much are longer thsan gti´s, and that means tha in cutting them , they will ofer much more rate vs the gti
i´ll probally will do it till the end of this week, if you want i´ll keep you posted on this :D
PostPosted: Mon May 06, 2013 4:51 pm
I still need to do this. Mine bottoms out pretty easily with the h&r mk2 rear springs.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Sun May 12, 2013 2:48 pm
data taken from on a replacemente parts website
the front kia sportage springs are the same diameter that the swift rears, inspite they are much taller
they are a direct swap, but have to be cutted, and get more stiffer
swift rears:
thickness 13,5 mm
outside diameter 121 mm
tall : 241 mm
kia sportage fronts:
14,5 mm
tall: 319 mm
the swap after cutting them was a hit
the rear doesn,t dance any more on the corners
had to cut them a lot in order to just fit 3 fingers between the fenders and the tyre, but the cornering was great and stifness also
great results
PostPosted: Mon May 13, 2013 9:38 am
Very interesting... do you have photos of the car in its current state? i would love to see images of it when it's drive only and then with some sort of
load in the rear (cargo/passengers)... I was also wondering recently if the increased 'Spring Rate' would affect the performance of the sway bar...
Alien
PostPosted: Mon May 13, 2013 10:00 am
Hi all... I went searching for other options at my favorite cheap store... I found a few candidates... not sure if they will do the job well though... your opinions are welcomed...
have a look see at the below links:
http://www.ebay.com/itm/280719571213?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
http://www.ebay.com/itm/280719571887?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
http://www.ebay.com/itm/220824846932?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
Alien
PostPosted: Wed May 15, 2013 7:50 pm
Alien
i ´ve cutted 3 coils on the kia front spring
the car seats great and handling it´s better that i´ve ever seen
i´ll try to take pics with two persons in the rear seats and empty
but the distance betwwen coils in kia springs it´s half compared to the gti rears :D
PostPosted: Wed May 15, 2013 7:53 pm
Alien
they all have 8 coils
so to cut them about 3 coils it´s ok
i had to fill the first coil in rubber to fit decently in the stock rubber donut, but it went very nice :mrgreen:
mine were used in decent conditions and shape, the car was form 2002 :D on a scrapyard they cost me here in Portugal with postage, about 60 euros, more or less the same in USD
PostPosted: Thu May 16, 2013 10:00 pm
Cool... I may be removing my full size spare and replace it with a donut to cut weight in the rear...
Alien
PostPosted: Thu May 16, 2013 10:03 pm
What's the significance of the numbers of coils? do you have photos of the rubber donut and spring combo?
Alien
PostPosted: Tue May 21, 2013 6:05 am
Alien
the number of coils it´s because those ones are from a 4x4 (fronts), so put in our rears has they are and you see :D
i cut one coil at the time to adjust the drop and don´t smash down a good pair of springs
but i can tell you that, the differences are in cornering, much stiffer and no bouncing on corners, and even wiht four persons on the car , plus the rear cargo compartiment almost full, it doesn´t it the rear bump stops on the shocks
i forgot to take photos :oops: :oops:
PostPosted: Wed May 22, 2013 12:23 am
Photos! :) ... I am getting some other issues on the car worked out before I purchase a set of those springs... As soon as you can,
post up those photos... :)
Alien
PostPosted: Sun May 26, 2013 8:30 pm
Alien
it´s a promise
tomorrpw i´ll take some photos
PostPosted: Tue May 28, 2013 8:59 am
Alien
it´s a promise
No worries man... :D
