It is currently Sat Oct 21, 2017 12:23 am
PostPosted: Sun Jun 24, 2012 1:31 pm
I have a 87 Sprint Turbo. I'm currently doing a makeover of the front end. Years ago I had a bad wheel bearing. A shop did the job. Instead of a bearing replacement, they got a junkyard knuckle and slapped it on. Now I'm working on it and I don't know what year knuckle they used. The bearing is completely different. The hub bearing diameter is different. The strut mounts points are different.
I would gladly buy a replacement if I can find one. Can anyone help with an ID of what I have to work with?
PostPosted: Sun Jun 24, 2012 4:54 pm
PostPosted: Sun Jun 24, 2012 6:53 pm
Man, somebody ought to sticky this thread, or move it to the MK1 section.
Yeah, I'm only going to say this once...(yeah right...)
and take a close look at this:
viewtopic.php?f=2&t=29003
Any bets this raises more questions?
PostPosted: Sun Jun 24, 2012 9:50 pm
I didn't realize there may be that many differences in the spindles, but the bearings are a dead giveaway that the used spindle was off of a n/a car. Is there a chance that those angle/dimension differences are because it's actually off of a mk2/3 car? I did tons of mk1's then moved to mk2+ but didnt do both styles at once so never did compare things such as spindles closely. I could be dead wrong about them bring remotely compatible, but from memory think they may generally resemble each other. I'd really try and find a mk1 turbo spindle, just to make it proper, regardless of what the mystery spindle is from.
PostPosted: Mon Jun 25, 2012 2:08 am
Phil N Ed, i had seen your picture, but I couldn't remember how things should line up when I was away from the computer and out in the driveway. I also read the thread you linked to. Now I'm confused about the possible year (MK1,MK2?) of the donor knuckle.
codyb76, I wasn't aware of the double roller bearing being the giveaway. Now it's not just a replacement knuckle. I would also need a different hub.
If anyone has a line on a complete LH Turbo knuckle, give me a heads up. By complete I mean knuckle with hub, backing plate, and associated spacers. The price of needed seals is comparable, as is 1 double roller vs 2 single bearings. I'm out the same cash either way. I really hate to put it back together the way it was, but I will if I have to. These little cars aren't very plentiful!
PostPosted: Thu Dec 18, 2014 6:39 am
@ssclown
What a totally awesome thread. I've got four Mark1 turbos and four mk1 non turbos that have all been daily drivers plus another Mk1 turbo and 2 more Mk1 non turbos that haven't been daily drivers yet but will be in the future and almost every daily driver non turbo ended up with severely hooped wheel bearings , which I got tired of putting new bearings into so eventually I put complete turbo knuckles on non turbo cars but now thanks to the pictures in this thread I can figure out which knuckle is which and sort them out. Thankyou.
PostPosted: Thu Dec 18, 2014 8:39 am
@ssclown
That would be awesome if Mk2 spindles can be bolted to Mk1 cars. Next time I'm at the wrecker I will get a Mk2 spindle and see if I can bolt it on to one of my Mk1 Cars.
