It is currently Sat Oct 21, 2017 3:47 am
PostPosted: Tue Dec 18, 2012 10:42 am
Have a line on some used lowing springs (Jamex I think). Do you have the alignment set to the same numbers as stock? On their web site there is a "note #40", but can't find out what that is. Was looking through the sticky suspension set up - hard to read - needs cleaned up. Thanks and Happy Holidays.
If your using more than 3 cylinders your just wasting gas.
I spit on hybrids at stop lights.
PostPosted: Tue Dec 18, 2012 5:51 pm
yep, the old suspension thread has been through a bunch of server upgrades and is a tough one to decipher with all the legacy zzcode and missing pics.
lowering springs tweak the camber a bit but you can get away without making corrections. the whiteline camber kit requires a front alignment and the manufacturer suggests a new rear toe setting.
one thing i'm keen on is replacing the rear toe control rods with tubular aluminum lateral links that don't flex like the flat stamped oem type. :wink:
