It is currently Tue Oct 17, 2017 10:17 pm
PostPosted: Wed May 08, 2013 5:00 pm
Hi all.
Having two issues. Having a squeaking sound from the drivers front wheel and shaking starting around 40-50MPH. Squeaking stops/starts at around 25mps and braking doesn't seem to change the sound. New tires installed today and have replaced the struts, outer tie rods, and alignment in the last 4 months. What do the doctors think?
Thanks
PostPosted: Wed May 08, 2013 7:29 pm
hows your inner tie rods looking? cause that can cause vibration also.
1989 Suzuki Swift GTI 2'' straight pipe from Cat back
1994 Suzuki Swift GT (My Brothers Car) Who is actually the original owner from 1994 when our father bought the car from the suzuki dealership! 80000 orig.miles currently
PostPosted: Wed May 08, 2013 8:49 pm
Thanks
viewtopic.php?f=2&t=29003
Maybe you've got a bad hub.
