It is currently Sun Feb 25, 2018 2:27 am
PostPosted: Wed Jul 24, 2013 11:22 am
Think I found a yard with a GT. Considering the conversion to disk on my Vert. Couldn't find a list of all the parts I would need and what would you say is a fair price?
PostPosted: Wed Jul 24, 2013 12:27 pm
I honestly haven't done the conversion but think I can cover it, here's a shot: spindles, hubs, rotors, pads, calipers, emergency brake cables, hoses, there's a Little rubber loop that holds each rear hose you should get, and make sure to get the distribution block(combination or proportioning valve? Can't remember correct term on these ones), it's mounted on the firewall splits the system up to send the right amount of fluid to rear discs to balance stopping power front to rear.
As far as value, I dont really know. If you get a system with good everything then I'd say it's worth more. If you are going to rebuild the whole system I'd try an pay a bit less, as you could be purchasing new pads,rotors,calipers, hoses etc upon install(which is the best way to do it, but brings cost up a lot)
PostPosted: Fri Jul 26, 2013 12:55 am
Covers it.
And if doing this to an mk4/5 add in control arms and toe rods. I paid about 120 for mine.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Fri Jul 26, 2013 7:05 am
I think I can you everything you need, but you''ll have to pay shipping...
image_id: 22616
1993 Swift Gti
