It is currently Sat Oct 21, 2017 6:13 pm
 Post subject: gt lug torque
PostPosted: Fri Sep 13, 2013 11:52 am
What is the torque spec for the gt wheel on 7 spokes?
___________________
89 Swift gti
 Post subject: Re: gt lug torque
PostPosted: Fri Sep 13, 2013 2:23 pm
i use a torque wrench and 45 ft/lbs.
i just removed a set and bolted on a replacement set not 30 minutes ago.
i got the torque spec from a supplement sheet to the swift fsm that was supposed to cover the aluminum rims and it's what i have run for several years.
the aluminum rims can warp so you don't want to wind 'em up too tight. :wink:
