It is currently Sun Feb 18, 2018 7:14 pm
 Post subject: gt front brakes
PostPosted: Mon Jan 20, 2014 3:22 pm
I have a stock front brake on my Sprint and I would like to know what parts I need to up grade to the gt rotors I have the rim space
 Post subject: Re: gt front brakes
PostPosted: Mon Jan 20, 2014 4:01 pm
You need Metro convertible front hubs and everything else from GT , you will need to machine about 1/8" from radius of the GT rotors and bolt everything together . While you are at it get convertible or Mk4/5 rear drums so you have M12 studs all around , they bolt right up.
Almost forgot , you also need hew Sprint drive shaft seals for hubs because Convertible seals are slightly different.
PostPosted: Mon Jan 20, 2014 5:24 pm
If I got gt calipers would that help with the clearance ?
PostPosted: Mon Jan 20, 2014 8:11 pm
That's with GT calipers , you cant reuse Sprint calipers . You can however buy whole Convertible hub with brake caliper , disc and just use that . Still a nice upgrade over stock Sprint brake set up
