It is currently Fri Oct 20, 2017 8:58 pm
 Post subject: Limiting straps
PostPosted: Mon Jun 02, 2014 2:14 pm
The racing springs I just installed don't stay captive when the car is jacked up.
Does anyone have any DIY solutions for Limiting straps, or is there a set I can buy...I looked and found nothing
___________________
89 Swift gti
 Post subject: Re: Limiting straps
PostPosted: Mon Jun 02, 2014 6:36 pm
Make love, not moderators
Some people cut a small slot in the bottom and top of the perches and use a gear clamp around the spring thru the notch to keep them in place.
PostPosted: Mon Jun 02, 2014 11:33 pm
if you wrap anything around a coil it gets pinched right off the first time the spring is fully compressed. i used safety wire/ braided cable and cable clamps to limit travel to maintain the bearing stack and keep the springs in their perches.
PostPosted: Tue Jun 03, 2014 8:37 am
Perfect! I will use that idea...you are like yoda
___________________
89 Swift gti
PostPosted: Tue Jun 03, 2014 8:57 am
A short piece of chain works. It's cheap and easy to buy, and easy to bolt on.
