It is currently Fri Oct 20, 2017 2:46 pm
 Post subject: Body reinforcements Help
PostPosted: Sun Oct 05, 2014 5:00 pm
Hello to all,
I am doing a refurbish to my swift gti mk3 cage and chassis.
My bodyshop tech recommended that after give the measures to 0mm tolerance to reinforce the front with some triangles on both side of the engine bay to reinforce the longeron like the photos below, since always I turn the car to right the car touches the tyre inside wheel arc on the left wheel and the measurements has only 5mm differences and the car feels very loose even after the upper and lower AA on front and rear.
Does anyone has some more ideas or points to reinforce since I am doing this work now?
Does anyone made something like that could share?
1992 MK3 Euro Swift GTI, Suzukird SS Exhaust header + freeflow SS exhaust + N1 Tip, Suzukird aluminum fuel rail + FPR, 60mm Nissan 200SX TB + K&N Air Filter, Reinforced OEM Clutch + Suzukird Short Shift + Aluminium Flywheel + Gripper 1.5 way LSD 30/70, Apex springs + Koni Sport Shock Absorvers + Wiechers Sport Upper Front Strut Bar + Upper RearStrut Bar + Below Front Strut Bar, Suzukird Underdrive Pulley, 15"x7" Antera Wheels + Bridgestone S03 195/50R15, Kevlar pads + SS Sloted rotors + SS hose kit
PostPosted: Sun Oct 05, 2014 7:33 pm
that looks good
you can also go through the a-pillar and run a bar along the bottom near the seat tie it into the b-pillar(attach it to your current brace you built) as well as tie one across behind the dash between the two sides (attach that in as well)
08 Civic Wife's car
PostPosted: Mon Oct 06, 2014 4:12 pm
crnolic wrote:
that looks good
Thanks for the help do you have any photos of what you suggest?
PostPosted: Mon Oct 06, 2014 5:03 pm
No sorry
Reinforcing the body is on my todo list one of these years lol
08 Civic Wife's car
