It is currently Sat Oct 21, 2017 4:22 pm
 Post subject: Wheel studs
PostPosted: Thu Mar 19, 2015 1:44 am
My 97 Geo Metro has 12 x 37 mm 1.25, knurled diameter 12.25 mm.
I am looking for a source for longer wheel studs. The 37 mm length needs to be 50 mm.
Fainya
 Post subject: Re: Wheel studs
PostPosted: Thu Mar 19, 2015 3:57 am
Subaru Wrx studs are also 12x1.25, I use the ARP extra long with tapered nose, only problem with the WRX listing is they are sold in packs of five.
PostPosted: Sun Mar 22, 2015 2:26 pm
Keep in mind you dont have to stay with 12mmX1.25. Just find somthing 12mm or 1/2" with the same knurle or close as you could drill the hub bigger. Any good parts stores should have a spec book for studs. I know I have one just not sure where.
PostPosted: Sun Mar 22, 2015 2:48 pm
and don't go for cheap ones.. some are made from butter..
also, because they're are longer and if they stick out of nuts, clear them (dust, sand, rust,..) before unscrewing nuts..
PostPosted: Mon Mar 23, 2015 4:52 pm
The closest I can com to what you are looking for is same knurl as 97 metro stud and 43 mm long. I looked thru catalogs for about a hour to day. dorman part number for stock is 610-336 12x1.25 thread knurl is 12.45mm length is 37.5mm the longest one I could find is dorman part number 610-402 12x1.25mm thread knurl is 12.45mm and length is 43mm. hope this helps.
Cars and Harleys
PostPosted: Mon Mar 23, 2015 7:05 pm
http://www.ebay.com/itm/OBX-16-Extended ... 2387wt_702
PostPosted: Wed Apr 22, 2015 11:29 pm
Thanks T3 and Ray. I will get one or the other. I need more then 5 turns that I have now to hold the wheels on.
Fainya
