It is currently Thu Jan 18, 2018 10:22 pm
 Post subject: crx caliper question
PostPosted: Tue Oct 06, 2015 6:38 pm
Hey so i have a caliper and theres a cap over one of the bolts, and i cant wrap my head around how to tighten this, unless the cap comes off?
___________________
89 Swift gti
 Post subject: Re: crx caliper question
PostPosted: Wed Oct 07, 2015 6:11 am
if my memory is good the lower pin is bolted on the caliper bracket and you just slide on & off the caliper on it, try to pull with you finger to see what inside the caliper( the other side in have thread on it ? or simply hollow and miss the allen bolt?)
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Wed Oct 07, 2015 8:21 am
Ah yep, you're right, can't wait to get these swapped over and try them!
___________________
89 Swift gti
PostPosted: Wed Oct 21, 2015 12:22 am
Looking good! Get your car ready and let's hit the track one last time for the season, hoping to go Nov 1st.
