It is currently Fri Jan 19, 2018 9:58 pm
 Post subject: Bias pedal box
PostPosted: Mon Jan 25, 2016 7:35 am
Alright guys,
Does anyone on here use or have used a bias pedal box in their swift gti?
I'm fitting carbs to my mk2 but the servo and master cylinder are in the way so they're going!
I've been looking at a complete pedal box kit and a brake/clutch kit.
They're not cheap so thought I'd ask before putting my hand in my pocket. Haha
Any help would be greatly appreciated!
Cheers dudes...
Slim
 Post subject: Re: Bias pedal box
PostPosted: Mon Jan 25, 2016 3:29 pm
I'm in the process of installing an OBP floor mounted reverse pedal box but requires serious modification to make it fit, if you have a dash bar then you might be able to hang a pedal box off it, if you're in the UK then OBP is much more affordable than a Wilwood or Tilton, you don't need the servo/booster ( prefer not having one) so you can run an MC in that position or alternatively relocate it to the other side of the engine bay like Dara/mad for tar.
Floor mounted requires moving the drivers seat a lot further back and steering to suit, here's mine.
