It is currently Sun Oct 22, 2017 4:10 am
 Post subject: carbie bolt on
PostPosted: Wed May 22, 2002 5:45 pm
i have the 1.3L sohc 8 valve (non gti) engine in my swift and have heard you can get twin weber side draft carbs for this engine. i'm in australia and am wondering where i can get the carbs and parts to do this add on. also is it possible to order over the net. how hard is it to put the twin carbs on my engine and is it jus a straight bolt on?? are the carbs hard to get them to work properly? does anyone have this conversion as i need some advice and suggestions. <p></p><i></i>
 Post subject: Re: carbie bolt on
PostPosted: Wed Sep 04, 2002 11:52 pm
You can ring up Suzi sport in queensland or NSW there everywhere there site is http://www.suzisport.au.com the can get you what you need <p></p><i></i>
PostPosted: Wed Sep 04, 2002 11:53 pm
You can ring up Suzi sport in queensland or NSW there everywhere there site is http://www.suzisport.au.com the can get you what you need.Keep me posted on how much power you make it should be around 30% and just how the car goes. Mine is an 88 model stock at the moment. <p></p><i></i>
PostPosted: Sat Sep 07, 2002 6:11 pm
Senior Member
If you check out Suzisport's site in the shop specials section...you can see an engine complete with twin carbs. With the carbs alone, I doubt you would get a full 30% - you'd need some head work and cams, intake and exhaust mods for that...<br><br>Give them an e-mail..they'll help out. <p></p><i></i>
