It is currently Wed Oct 18, 2017 2:12 pm
PostPosted: Tue Jun 25, 2002 9:35 pm
Hey Bados gti. I'm from here too, my swift is red and in desperate need of a paint job. lol lol lol Anyway I want to get in contact with you dude! my cell number is 231 0074 call me dude! Let's meet for a lil test out of machines! Well this is to bajan gti as well! call me dude!!!!! <p></p><i></i>
PostPosted: Wed Jun 26, 2002 1:24 pm
That sounds good <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> I'll definately give u a buzz sometime soon. If want to get me before hand try 230-0569. <p></p><i></i>
PostPosted: Tue Aug 27, 2002 3:39 pm
hey ppl, well that makes the three of us that is from BIM. <!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Thu Aug 29, 2002 11:09 am
Hey nuformz, it's good to see another bajan in the place. I'm thinking about trying the Bluebird TB. Do you know where I can get it (or the SR20 TB)? <p></p><i></i>
PostPosted: Thu Aug 29, 2002 2:56 pm
i will see if this due still has the other one, but on the other hand i'll still ask around for you. have not put my on as yet.<br>so what mods do you have, what is the colour of the car and lic plate #. <p></p><i></i>
PostPosted: Sun Sep 01, 2002 11:25 am
And now there are four...<br><br>I got my 60mmTB from autoworld in green hill. You can try Transtech but there prices are outrageous....<br><br>Word of advise to the bajan posse...don't believe every thing you read on this (or any) forum. Also, if there are any runs going down call me @ 233-1946.<br><br>Mandingo <p></p><i></i>
 Post subject: MF89
PostPosted: Sun Sep 01, 2002 12:12 pm
hey MF89 is that your number plate, if so would that make you a RED GTi?? <!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"><!--EZCODE EMOTICON END--> am i correct. how much did you pay for your TB and did you feel a difference?? . did you or anyone else here did anything with there AFS as yet?? if yes who did the job?? <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/unuformz.showPublicProfile?language=EN>nuformz</A> at: 9/1/02 12:13:28 pm<br></i>
 Post subject: anyone
PostPosted: Sun Sep 01, 2002 12:16 pm
if one gets this in time and you also have time come up bushy park today 2002-09-01 or you could land in six roads gas station to night for a lil lime. <p></p><i></i>
 Post subject: Re: anyone
PostPosted: Mon Sep 02, 2002 7:31 am
I paid 200Bds for the 60mm Nissan TB. There was aslo a noticalble increase in throttle response especially @ 4000+ rpm. However, there are a few things that you should know. You have to match port the intake manifold inlet port. There is no idle adjust valve like the GTi TB, however the idle can be correctly set using the throttle stop screw (8mm) on the TB. The Nissan TB spring is not as tough as the GTi which makes the excel peddle very soft and sensitive (false response). The GTi excel cable will not properly into Nissan TB, but thats not a problem....the Gti excel cable holder can fit but you'll have to drill/file the hole a bit so that it can fit onto the trottle shaft. You'll also have to afix the decelleration valve from the GTi TB onto the Nissan TB. This is needed for smooth decelleration. <br><br>The MAF housing is very thin and can only be ported about 1mm. Use 3" alluminum from the TB to air filter collection box. Drill a hole, use a rubber gormet and insert the MAF. Modifing MAF signals are very complex and wasn't need. Get an air/fuel gaugle and you'll see. You can also try adjusting the CO2.<br><br>Mandingo. <p></p><i>Edited by: <A HREF=http://pub83.ezboard.com/umf89.showPublicProfile?language=EN>MF89</A> at: 9/2/02 7:52:58 am<br></i>
PostPosted: Mon Sep 02, 2002 8:32 am
It's good to have some more Bajan company on this forum. Thanks for the advice on the TB mods MF89. I notice in one our your earlier posts you are using a Haltech E6k what kind out turbo are you using? I was thinking about aftermarket engine management for later down the line. Who did your wiring? <p></p><i></i>
PostPosted: Mon Sep 02, 2002 1:54 pm
I am using a Garrett GT320HP turbo. Its max cfm of 22psi @ 3K rpm. I did the E6K wiring and tuning myself. If you a serious about performace and reliabilty a programable aftermarket ECU is the only was to go. Forget about MAF signal and preset plugin chips. There are many and quite affordable...sds, haltech, motec, wolf3d, apexi<br><br>I have done quite a bit of work on the car and it should be completely finished by monthend (09/02). I'm in search of a G16B bottom end w/ good crank. Does anyone know where I can find one? <p></p><i></i>
PostPosted: Tue Sep 03, 2002 3:42 am
Hey MF89 we have to link (and the others to) but I was thinking about doin the same thing with the AFS. I would still like to see your setup. you or any one here can get me 427-0776 anthony <p></p><i></i>
PostPosted: Sat Sep 14, 2002 11:15 pm
Yo wassup.<br> Unfortunately I am no longer in Barbados. I am back in Toronto at school. Won't be back in Bim till X'mas. Too bad none of us met up during summer. It would be nice for all the Gti's in Bim to get together regularly. I know quite a few. It would be quite a large and impressive group. Anyway keep me posted on whats going on back home.<br><br>later.<br><br>p.s my car is a white Gti 92 model. x2104 <p></p><i></i>
