It is currently Sat Oct 21, 2017 12:32 pm
PostPosted: Thu Oct 31, 2002 11:23 am
banned
time for some more controversy <!--EZCODE EMOTICON START :evil --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/devil.gif ALT=":evil"><!--EZCODE EMOTICON END--> <br><br>my friend has a 95 gti with some mods, lightened flywheel, itake 2 inch pipes blah blah blah<br><br>anyway, his accelerater cable is always slack! i drove the car and the pedal feels 'light' like nothing is under it, as opposed to 'heavy' <br>anyway, i was confused, he came to me on friday in desperate need for speed for weekend 'brawls'<br><br>i took off the bracket that holds the cable and bolted it in the hole abobe that one...<br>tensioned the two bolts that adjust the cable so its 'just right'....<br>turned down the idle screw ALL THE WAY to keep it slightly above 1000(lightened flywheel)....<br>also extended the screw that colides with the deceleration valve to not drop revs so much...<br><br>THE GUY IS THE HAPPIEST MAN IN THE WORLD!!!!!!!!!!!!!<br>the car flys through 1st and spins second without even trying!!!!!!!!<br>before he had a 'pick up' in 2nd and third but now its instant acceleration!!!!!!!!<br><br>and all this was free!!!!!!!!!!<br>well exept for a small 'beer' money <!--EZCODE EMOTICON START :evil --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/devil.gif ALT=":evil"><!--EZCODE EMOTICON END--> <p></p><i></i>
 Post subject: deceleration valve
PostPosted: Thu Oct 31, 2002 11:47 am
Ther's a valve that can be adjusted for the deceleration? I didn't know that... were is it located? I always find my car just drops to 1000 way too fast when I hit the clutch...<br> <p></p><i></i>
 Post subject: Re: deceleration valve
PostPosted: Thu Oct 31, 2002 6:47 pm
banned
it seems no one knows about this valve but me!!!!!<br>its hard to explain whare its located<br><br>ok, the 'spring' that goes down when you accelerate, when you take foot off the spring will come back up, it is supposed to hit the valve and decelerate gradually, these valves normally dont wotk properly, ive seen a proper working one and it comes out about an inch...<br><br>it bolts onto the intakemanifold right beside the 'throttle linkage' i believe, hard to describe, its circlish? <p></p><i></i>
 Post subject: valve
PostPosted: Fri Nov 01, 2002 8:08 am
Okay I know witch one your talking about but it can be asjusted??<br> <p></p><i></i>
 Post subject: Re: valve
PostPosted: Fri Nov 01, 2002 8:59 am
They can be adjusted easily with a small flat screwdriver. Be carefull not the break or strip this cause there about $160 CDN.<br><br>Jake <p></p><i></i>
PostPosted: Fri Nov 01, 2002 1:11 pm
The screw your turning is the throttle stop screw. This screw is set and sealed at the factory and is the reference point for setting the throttle position sensor. By turning it you are making changes to the signal that the TPS sends to the ECU. I'm not sure thats a good idea. <br><br>The factory manual has this warning : <br><br> "CAUTION:<br> As throttle stop screw is factory adjusted precisely, don't remove or adjust it."<br><br> The throttle cable is adjusted by turning the nut at the end of the cable until there is between 3 and 5mm of deflection in the cabe <p></p><i></i>
 Post subject: HAHA
PostPosted: Fri Nov 01, 2002 4:07 pm
lol, i nearly laughed when you said that, Jomo stopped listening to the warning's in the manual a long time ago, he does anything to make the car go faster! <p></p><i></i>
 Post subject: Re: HAHA
PostPosted: Fri Nov 01, 2002 11:06 pm
jomo is refering to the dashpot<br><br>i dont think adjusting it will make you car any faster <p><!--EZCODE LINK START--><a href="http://www3.telus.net/tc2468/">Tom's webpage</a><!--EZCODE LINK END--><br><br><!--EZCODE IMAGE START--><img src="http://www3.bc.sympatico.ca/tc2468/small2.gif"/><!--EZCODE IMAGE END--></p><i></i>
PostPosted: Sat Nov 02, 2002 11:32 am
banned
what warnings in the manual, i dont think we get warning pages in jamaica... <!--EZCODE EMOTICON START :smokin --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smokin.gif ALT=":smokin"><!--EZCODE EMOTICON END--> <br>you guys are cool man <p></p><i></i>
