It is currently Sat Jan 20, 2018 11:45 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat May 19, 2007 10:36 pm
the 4agze rods and 75mm vitara pistons sounds like an interesting option without major modifications to the piston required. typically you use the 75mm vitara pistons to lower compression for a TC setup, but with a NA setup the 2mm longer 4agze rods and 75mm vitara pistons combo with the right head gasket thickness (or stock vitara gasket) could bring the compression back up on a NA setup.
really like the idea of having more torque. anyone has more ideas on this?
Lee, Singapore
PostPosted: Sun May 20, 2007 3:35 am
Hmmm, the vitara pistons are lower compression because they have quite a deep dish compared to the gti pistons, 2mm is a lot, I suspect you would have to machine the top's off the vitara piston to prevent it from hitting the valves using 4agze rods.
PostPosted: Sun May 20, 2007 7:48 am
so it's a viable option to use the 4agze rods together with the vitara pistons. 8)
the raised edge on the vitara pistons is where material can be taken off.
Lee, Singapore
PostPosted: Sun May 20, 2007 9:07 am
I did the maths. Vitara pistons + these rods will lead to 8.9:1. Machining the tops will lead to even lower values.
PostPosted: Sun May 20, 2007 10:21 am
Seb,
Thanks for the calculation. From your experience would there be enough clearance between the pistons and the valves? Sounds like a much better option for TC engine than a NA engine.
Lee, Singapore
PostPosted: Sun May 20, 2007 4:55 pm
Yes, I guess the pistons will now protrude, and touch the head. Machining the tops becomes mandatory. I don't think it's a good option.
