It is currently Thu Oct 19, 2017 4:20 am
PostPosted: Mon May 28, 2007 5:30 pm
I've been doing some reading up on Megasquirt II and I've seen a couple of people on this board running MS on their 1.3L cars, but has anybody used MS to control both fuel and spark on a 3-cylinder engine? I was thinking a person could use an EDIS-6 (no more wasting sparks :D ) but how to address the timing trigger?
PostPosted: Tue May 29, 2007 8:24 am
What about the crank angle sensor on the later model 1.0l? Just an idea..
Bob
-Bob
PostPosted: Tue May 29, 2007 11:20 am
Thanks Bobross. I didn't realize the 96+ have a crank position sensor right from the factory. I did a search on "crank position sensor" and found this interesting thread: http://www.teamswift.net/viewtopic.php?p=103394
It sounds like I would need the block, oil pump and crank from a 96 so unless I'm missing something, I'd be further ahead just using the whole short block from a 96 and pairing it up to the top end from a 91 turbo firefly. There appears to be some variations in the pulleys I might have to worry about though.
