It is currently Wed Jan 17, 2018 3:24 pm
 Post subject: Intake Manifold
PostPosted: Tue Jun 05, 2007 10:06 am
Hi, does anyone know if there is any difference between MK2 and MK3 intake manifold? Any parts other than the hollow cams can be used on the mk3 for performance?
Cheers!
PostPosted: Tue Jun 05, 2007 7:13 pm
Hmm, I don't think there are any more parts from the mk2 to be used on the mk3. They are pretty much the same. But the mk1 GTi on the other hand I heard had stronger crankshafts and a very lightweight crank pulley.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Tue Jun 05, 2007 8:03 pm
I asked the im question a little while back and they should be the same.
PostPosted: Sat Jun 09, 2007 9:23 am
The mad quebecer
The mad quebecer
Mk2 has the PCV valve on the plenum while Mk3 only has a nipple. The PCV valve is located on the valve cover for these models.
PostPosted: Mon Jun 11, 2007 7:49 am
There are some minor cosmetic differences between the EFI plates. '89 models I believe had them mounted with cap screws.
