It is currently Tue Jan 23, 2018 9:36 pm
PostPosted: Tue Jul 03, 2007 4:21 pm
If I can get it done cheap enough, I'm thinking about having an aluminum crank pulley machined up for my 1.0L. It wouldn't be undersized, it would simply be lighter and without the groove for an AC belt. The stock pulley is just a one-piece, unbalanced steel unit isn't it?
PostPosted: Tue Jul 03, 2007 5:38 pm
that is correct, because they use the same pulley for the 4cyl and 3 cyl motor
93 Geo Metro - 3Tech 10 Degree Pulley, UDP, Foam Intake, Two Brothers Racing Muffler
PostPosted: Tue Jul 03, 2007 7:30 pm
Really? I thought all the debate on here about UDP pulley's ruining bearings and cranks was because the factory pulley's on the 4 bangers had rubber of some sort acting as a balancer and the aftermarket ones didn't.
PostPosted: Tue Jul 03, 2007 7:35 pm
"some" 4 cyl engines have rubber dampened pulleys, some do not. Off the top of my head I can think of a few motors that don't have the dampened pulley
1) Turbo and non turbo dodge 2.2/2.5s
2) Mitsu 2.6 motor
3) DOHC 2.2 T3 dodge motor
4) some 1.8 and 1.8t VW motors
If you motor doesn't have the rubber dampener, then I wouldn't worry at all about an UDP doing anything other than freeing up some power.
If however you have a dampened crank pulley, it "may" shorten engine life but by how much no one can accurately say, might be 1% might be 50%
PostPosted: Tue Jul 03, 2007 9:58 pm
2) Mitsu 2.6 motor
Most of those motors have chain driven balance shafts.
PostPosted: Tue Jul 03, 2007 10:41 pm
Only in the 2.5 dodges for sure, not 100% on the 2.6s or VWs
PostPosted: Tue Jul 03, 2007 11:40 pm
Great - thanks for clearing that up for me Garret. Now it's just a matter of finding someone capable & willing to make one for a price I can afford.
PostPosted: Wed Jul 04, 2007 6:44 am
Misubishi 2.6 has balance shafts. Trust me, you do not want a four cylinder that big without balance shafts.
PostPosted: Wed Jul 04, 2007 4:26 pm
well I've ran several 2.5s without balance shafts and there was zero diffence in the smoothness of the motor, but those 2.6s weren't exactly the greatest motors ever
