It is currently Fri Oct 20, 2017 6:29 pm
PostPosted: Sun Sep 02, 2007 9:34 pm
To start off with I'll tell you what I already have.
3Tech cam 226/395
Head planed .020 and ported
Weber 32/36 carb
3Tech under drive pulley
Should i go with flat-top or dish-top pistons? Also, would 75mm pistons be too much? This will be a street driven engine, so I want to keep it on pump gas.
Thanks in advance.
Project Page
Image Image
PostPosted: Thu Sep 06, 2007 7:28 pm
Any info will help...........
Project Page
Image Image
PostPosted: Thu Sep 06, 2007 10:09 pm
Dish top will lower the compression ratio of the engine. But should result in a more efficient engine due to the cupping effect of the piston against the flame front of the expanding and now burning gas.
Basically, take a look at what the pistons do to a stock engine for compression. See what your mods do for compression.
eg. stock pistons(S): 9.5:1, dished pistons(D): 8.5:1, mods to head(M): 10.5:1
S - D = Difference + M = (new compression ratio)
You still end up with a 9.5:1 compression ratio. You take the difference from the dished piston and the stock piston and take it away from the head mods to get your new compression ratio.
Simple math is always best. So your high end for pump premium is about 11:1.
PostPosted: Thu Sep 06, 2007 11:30 pm
So from this info, I tend to lean towards dish-top. I think I can dig up some reasonably priced 75mm dish-tops.
Project Page
Image Image
PostPosted: Thu Sep 06, 2007 11:34 pm
You should already have flat top pistons, and that is what I would stick with.
In a Mk1, .020" not alot of material to remove from the head, and if you are looking for performance, you could easily take .040", or more, up to about .100", if I recall.
GT pistons, and rods would be a nice addition, and valve clearance should not be a problem.
PostPosted: Fri Sep 07, 2007 9:46 am
If i can get some reasonably priced rods, I would like to use those. I found a set of decent priced 75mm flat-top pistons that i think I'll use.
Project Page
Image Image
