It is currently Sun Oct 22, 2017 9:30 am
 Post subject: G10 Full Length header
PostPosted: Fri Sep 28, 2007 8:07 am
I have a header of a gs 1100 four cylinder that I have been planning to cut one of the tubes off to make a full length header for my metro. I was going to start fabbing up the flange today, but then I got to thinking, instead of taking a bunch of time to make a new 3 into one collector; I started wondering if I just cut off one of the pipes on the 4 into one and beat it down flat with the other three and welded up the hole if it would still scavange, or will the flow be all screwed up.? I can make a new collector, I just didn't want to waste the time if I don't have to.
93 Metro G10 MT
Removed TB Bridge, Advanced Timing, Removed Air box, Soon to be full length header, and advanced cam gear
PostPosted: Fri Sep 28, 2007 1:55 pm
Bozo the crying clown
Give these guys a try.
I have their race header and it is VERY nicely made...
Bolts right up and still looks great after 4 months :-)
http://suzukird1.com/catalog/index.php
Jimmy
PostPosted: Fri Sep 28, 2007 2:04 pm
Unfortunately Suzukird is pretty much about the only place that has an off the shelf header for the 3 banger, the quality and fit is rather hit and miss, do some searching and you will find that some guys can bolt it straight up while others have to spend an hour with a die grinder port matching the flange.
PostPosted: Sat Sep 29, 2007 2:01 am
That and their is no warranty on any of their stuff, so if it don't fit/work, your SOL in their books. You can return for a 30% hit if it is in perfect shape.
Makes me leary.
My cars:
PostPosted: Tue Oct 02, 2007 7:43 am
Well, it beats having to make your own.
Unless you're an engineer and a welder. ;-)
I would buy from them again...
BTW...I've NEVER seen ANY type of warranty on racing parts for ANY car.
Even from the dealership.
PostPosted: Tue Oct 02, 2007 10:04 am
In most cases warranty covers defects due to manufacture and material, however because of the very nature of racing, where equipment may be stressed beyond design specification in the heat of the moment, it becomes difficult if not impossible to determine if a failure was caused by defective manufacture, material or stress - so warranties are not usually offered.
Fit is a different issue - take it out of the box - and offer it up to the head, it either fits or it doesn't, there's no stress involved - if it doesn't fit, it's a clear case of defect due to manufacture.
I'm not an engineer or a welder and if/when I buy a header I'd expect the flanges to be flat & inline, and the holes to line up, no grinding required - which does not match the pictures I've seen.
PostPosted: Tue Oct 02, 2007 3:04 pm
Exactly, and I've read a few different pieces where alot of things from SRD don't fit, you either chew a restock fee or you break out a grinder.
It takes nothing to guarantee fitment for what you are advertising. :D
My cars:
PostPosted: Tue Oct 16, 2007 4:57 am
Have asked this question B4, but got no response. Does anyone know if I can still use oversize oil fltr(PH8A) w/this header? There's about .5" clearance to closet part of stock exhaust system using this fltr now.
PostPosted: Mon Oct 29, 2007 11:51 pm
as soon as i get my morrison test guage up and running i'll be in production of calculated 3-banger headers as well as full (no cat) ehaust systems. they will be bench tested, and guarenteed to work & fit. i'll try to bang 'em out for a reasonable price once i get everything in line...
;) :lol:
PostPosted: Tue Oct 30, 2007 12:15 am
You've got at least one customer waiting over here 8)
PostPosted: Thu Dec 20, 2007 10:02 pm
Make that two!
 Post subject: Re:
PostPosted: Thu May 08, 2008 11:07 am
Jimmy
did you noticed better throtle results???
PostPosted: Fri May 09, 2008 11:30 am
The headers work great. Great throttle response and wil breateh a HELL of alot netter than stock. You'll be able to rev sky high and still have power.
Drawback/s???? The headers block the egr port and make the check engine light stay on. You won't be able to pass emissions. :-(
If you don't ming that, then they are a hit! :-)
If you're interested, I have one for sale. ;-)
Jimmy
PostPosted: Fri May 09, 2008 2:50 pm
Jimmy
may i ask the price??
i´m in europe so i assume shipping will be expensive
send me a pm
PostPosted: Fri May 09, 2008 4:19 pm
Jimmy
That's an interesting comment - it's predictive rather than a statement of fact, as if you're telling us what to expect rather than what you experienced.
- will breathe ... netter rather than breathes netter (what ever netter means ;) ) and you'll rather than you can.
'93 1.3 Swift GLX
'98 2.0 Grand Vitara
PostPosted: Fri May 09, 2008 5:58 pm
fordem wrote:
Jimmy
Hope it's not like mine...
Well atleast he didn't get the unfinished lottery...
Mine looks like a sizeable upgrade from the factory manifold.
But... I still have to grind it, peel off the crappy chrome coating, finish welding, grind, cut open the collector, clean up some bad welds, weld in a spear/spike, then send it off for $200 in ceramic coating, and then finally get to install it. :blackeye:
But I did get the bolt together flange included for free... soo.. I suppose it could be worse... :roll:
My cars:
 Post subject: Re:
PostPosted: Wed Jul 02, 2008 8:42 pm
Bump... any info, or did that not pan out for ya....
PostPosted: Wed Jul 02, 2008 9:47 pm
image_id: 14451
This is the summary picture of a SuzukiRD header.
My cars:
PostPosted: Sun Sep 07, 2008 1:04 am
the best part of suzukird headers is the only one unfortunally and for the question about fits with a larger filter, yes, It's fits, I'm using the best headers for a 1.0 and a HP 3001 K&N oil filter
File comment: 1.0 suzukird headers with large oil filter
air filter 5.jpg [285.5 KIB]
Downloaded 2170 times
nothing sweetest than fits everywhere at 65 mph!
PostPosted: Mon Sep 29, 2008 1:35 am
Dumb as a post
Anyone know of a way to trick the computer by using a resistor somehow to turn off the check engine light. After getting rid of the egr.
Super highly modfied 1.0. LOL
Engine:
Mike's head and cam, +10 cam gear, 42mm tb, .30 over rebuilt block, under drive pulley, lightened flywheel, suzukird header, full 2in exhaust, MSD ignition. Much more
Suspension:
KYB Gr2's and H&R Sport springs
Future mods. Short shifter, safc, sway bars, front and rear strut braces, Underbody brace, Port tbi housing, Brake upgrade.
PostPosted: Mon Sep 29, 2008 9:41 pm
where did you get that header from?
PostPosted: Mon Sep 29, 2008 9:50 pm
Dumb as a post
http://www.suzukird.com
Engine:
Suspension:
PostPosted: Sun Oct 05, 2008 11:57 pm
I installed the SuzukiRD header before my Spring vacation in SoCal. Yes, it was expensive (see "racing"). Their customer service guy, Andy, was very helpful. Yes, I needed an O2 sensor bung. Yes, I should get the flange attachment. Gasket plus shipping and having a shop weld it was like $450US. You can drill, weld on an eBay O2 bung and reinstall sensor to get the CE light to go out, if you have to.
I posted this before and most of you have your decisions made but I think it was worth every penny. Not for everyone. It is louder, lower and not approved in 50 states for smog, ie save the old one(?). No shop would touch the header, I had to bolt it on and drive it down to have the Catco Cat. and glasspack welded on. Added a chrome muffler tip to get some sound waves beyond the fender. I wrapped mine (less heat) and painted it silver (2000 deg.); Thermo Tec.
Priceless: 85 on the 405. Crusing by the Ferrari and BMW dealers in Newport Beach at 5K rpm, rap the throttle and watch heads turn. Oh, made some noise leaving a local car show also. :D
Have fun,
Bad Bent
