It is currently Sat Oct 21, 2017 3:26 pm
PostPosted: Sat Oct 13, 2007 3:43 am
Hi, All!
Has anyone thought of making a supercharger from an old waterpump?
I'm thinking of it right now. Is it going to work or......?
Extreme racing team
PostPosted: Sat Oct 13, 2007 5:49 am
An automotive waterpump? They won't make any pressure.
A waterpump from a house seems more likely, if they can be run dry without damage. But they're really heavy.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Sat Oct 13, 2007 7:56 am
Domestic waterpumps use a ceramic seal where the shaft enters the housing - if the pump is operated dry the seal will overheat and burn.
PostPosted: Sat Oct 13, 2007 10:29 am
So It won't work :( :( :( :(
I've tried something else but it gave only a momentary boost.
I was testing an electric air horn to see if it would make ant difference in
performance but didn't satisfy my "expects".;-)
Anyway....
10x for the quick replies
Extreme racing team
PostPosted: Sat Oct 13, 2007 6:33 pm
Mr Ness wrote:
I was testing an electric air horn to see if it would make ant difference in performance
Jomo?
PostPosted: Sun Oct 14, 2007 8:49 am
After seeing the leaf blower video I'm really surprised that no one has yet to try using one on one of our cars. Theres enough room under the hood to mount up a stripped down leaf blower and run some piping...
Probably won't give huge gains, especially up top, but it might pick things up at the bottom end *shrugs*... just figured I"d throw that one out there for Mr. Ness
-Bob
PostPosted: Tue Oct 16, 2007 3:40 am
Yes, I've read about the leafblower thingy;-)
I was thinking, maybe two or three air horns with lines fitted directly
in the filter housing(1.3 SOHC TBI engine), will give a momentary
gain approx. 2 or 3 seconds at WOT.
I'll try things and report it!
Extreme racing team
 Post subject: supercharger
PostPosted: Sun Nov 11, 2007 10:46 pm
what about using a blow dryer to force air. just take out the heating element and there you go. and electrical just get a power inverter and a switch to turn it off and on. remember just an idea.
PostPosted: Sun Nov 11, 2007 11:48 pm
Location: dunnville, ontario,canada,the world,the universe
haha i thought of something like this before too haha, except using an airtire tank (for pumping up flat tires) you can get them at crappy tire here in canada or im sure any other automotive place. run a fatter hose from it with a fitted fitting on your intake (closer to the throttle the better the air gets there and colder) run a valve on that piece of the hose (from tank to intake) then fill up the tank to about 100psi (usually hold over 100psi like 120 -130psi) tanke it for a rip and open the valve. :wink: kinda like a supercharge effect but your not drawing any power or anything for the charge from the car too. just have to refill the tank every run down the track hahahaha.
thats something i thought of before
PostPosted: Mon Nov 12, 2007 8:20 am
the hair dryer won't work.
A - the volume is just too low
B - it doesn't build enough pressure
C - running it off an inverter powered by the car itself is counter productive... it will require more horsepower to power the hair dryer than it could make (which it couldn't do anyway)
The air tank won't work either, not unless it's a huge tank filled to hundreds if not thousands of psi. A regular portable air tank that racers use (and that are available at auto stores) is probably only enough air for maybe 10 to 20 revs at wide open throttle, so you'd use up all the air after traveling 6 inches (actually, probabaly more like 1 cm).
2009 Cannondale Rize
PostPosted: Mon Nov 12, 2007 9:48 am
well, then how about some of the old "smog" pumps,
like the one that "just happend to fall off" :wink: of 2 of my
old toyota celicas the one witht he 22r's. they were
used to pump air into the exhaust for some reason.
I was thinking if you could mount one (belt driven)
then reduce the pulley in size to spin it a little faster,
dont know since im not a mechanic :( but that is what
just popped in my head (or circut breaker) :shock: when i
read this post.
trying to go turbo but the wife thinks it will cost too much for my 93 metro so now i have to "wheel & deal" my way there, any help would be great.
PostPosted: Mon Nov 12, 2007 3:31 pm
The smog pump pumps air into the catalytic convertors to reduce emissions. I've seen them used on small engines like Honda or Briggs & Stratton single cylinders but it wont do squat to your car.
Scott
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Tue Nov 13, 2007 8:18 am
somebody did an internet artical somewhere about putting a very large air pump from a full size pickup truck on a small bore commuter car, and it showed positive results.
But for the amount of work it would take, why not just bolt on a supercharger?
