It is currently Wed Jan 17, 2018 6:33 am
PostPosted: Thu Nov 29, 2007 6:04 pm
Hello.
I need help about how I increase HK and Nm in one Suzuki Swift GTI 1988 rally car. The engine is new built and I’d like to tune it some, but I don’t know so much about tuning an injection car. :?
May not change a lot parts, but can of course change cams, throttle body, air intake, port the header and I already have 2inch exhaust system and maybe assemble an adjustable fuel press regulator.
Any tip what kind of cams I can use, size of throttle body to gain more power? Have looked at cat cam: http://www.catcams.be/800x600/prod01Ali ... 67006xx.js
Partnr.______Duration______Duration______Maximum lift______Lift at TDC______Parts
6700604____269/261______225/217______10.00/9.00mm_____1.25/0.90mm____O.E.M
If I buy these cams, what more do I need to rebuild in order to increase HK? How much may the power increase?
Thankful for all tip.
/Piggen :wink:
PostPosted: Thu Nov 29, 2007 6:59 pm
You should be sending a message to superf1y(mike) on this forum. He is a cam expert and has many various setups for the gti engine. As for hp and torque your intake and exhaust are the first easy things you can tackle. Im not sure if you have one already but a header can make a nice addition to your exhaust system.
PostPosted: Sun Dec 02, 2007 8:27 am
i have this cams powerband 6000-8500 are the best cams for swift in my opinion
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Mon Dec 10, 2007 5:30 am
OK which modifications are needed to be done for those cams?
Would it be enough with increasing the fuel and to change the ignition?
Or needs it to be replace some parts?
PostPosted: Mon Dec 10, 2007 5:36 am
I haven’t done any modifications with intake and exhaust yet, what do you suggest?
About header so unfortunately aren’t I aloud to use that in my group in rally…
