It is currently Mon Feb 19, 2018 3:25 am
PostPosted: Tue Dec 04, 2007 10:25 am
Hi, I have a 1991 Suzuki Swift GT 109,000 miles. I have problems in the
morning starting the car. I turn the key the engine cranks 3 times then it
starts but, if I don't give it some gas right away the engine will shut
off ! After the first start of the day my car starts up right away with
no problems. Could it be a battery issue? I had someone check the
battery and it's reading 12Volts. It's winter time here where I'm at in
N.Y.C. Maybe overnite it's too cold out and the battery is not putting out
the power to start the car or something? Anyway I have no idea what it
is. If anyone can help me out I'd appreciate it.
Thanks, 8)
PostPosted: Tue Dec 04, 2007 12:09 pm
How much cca is your battery? I had a battery with 800cca in my gt and the thing started all the time. Never plugged it in once. It ran everyday, but i never had a problem starting it. I found that the smaller stock batteries didnt really satisfy me for the winter.
PostPosted: Wed Dec 05, 2007 3:36 pm
I have a duralast battery #51-DL
CCA 425
Reserve Capacity 75
Cranking Amps at 32 degrees is 530
This battery came with the car when I brought it back in June of this year. Is this the right battery for this car?
PostPosted: Wed Dec 05, 2007 3:54 pm
Mama Said Knock You Out!
When I had my 91 gt, it did the exact same thing. I never actually figured it out, but it was usually when it was under 25 degrees outside when it did it. It shuts off so suddenly it's like the key was turned off right?
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Wed Dec 05, 2007 4:05 pm
Yea, I can't even move the car unless it's been warmed up for 5 or 10
min. But after that it starts up like normal even after being parked for a
few hours. :shock:
PostPosted: Thu Dec 06, 2007 7:53 am
could be a bad water temp sensor....
*edit*
Do you have an ECU chip or any other type of tuning device in the car?
2009 Cannondale Rize
PostPosted: Sat Dec 08, 2007 3:34 pm
I don't think I have an ECU chip or any other type of tuning device in the car? How could I check?
PostPosted: Sat Dec 08, 2007 3:54 pm
When I get money for a new battery I'm going to try that and see if it works out. Could I use a battery with a higher cca like around 800 or something? It can't hurt the car's engine if I did something like that could it? Also does anyone know what is the stock requirement cca for this cars battery?
"Sometimes using all of your strength means asking your friends for help!"
PostPosted: Sun Dec 09, 2007 6:04 pm
Oh yea go big on the cca. I did on my whtie gti and it was noticable compared to the stock battery.
PostPosted: Mon Dec 10, 2007 7:18 pm
Well, lack of a rev limiter would be a dead giveaway, but some chips don't remove the rev limit.... What does your engine rev to?
PostPosted: Tue Dec 11, 2007 1:30 pm
Roy what you mean the RPM gauge? On idle the engine revs high in the mourning like 2RPM on the dash gauge. Then after it warms up it will go back down to !RPM.
PostPosted: Thu Dec 13, 2007 12:35 pm
No i think he means when your driving the car hard what can you shift at, can you go up to 8000rpm or do you get stuck at a rev limiter?
PostPosted: Fri Dec 14, 2007 12:59 pm
Ya know, that's funny, cause my old white swift didn't have a rev limiter either, but it wasn't chipped. I replaced my water temp sensor at one point to fix the problem, and that did nothing at all. You didn't happen to buy an ECU that used to be mine did ya? :lol: Or perhaps there was a run of swifts with a faulty program in them?
PostPosted: Wed Dec 19, 2007 9:53 am
I think it can go up to 8000rpm I'm not going to try and redline it because that's bad for the engine right? No it drives like a champ I'm more than happy with it. It's just a little tricky to start. So far I pump the gas two times then I turn the key and it cranks 3 times then it starts up after that I have to hit the gas one more time then it idles fine. After that its good all day starts right up! Wierd right!?! :shock:
PostPosted: Wed Dec 19, 2007 1:35 pm
No - redlining the engine is not bad for it - at least not a healthy engine. One of the best tuners I know would routinely recommend redlining the engine at least once a day, and I've been doing it with my Swift for over 10 years without problems.
PostPosted: Thu Dec 20, 2007 3:07 am
Before those of you younger drivers in the northern latitudes take to daily redlining, you might want to consider your ambient temperature.
Sometimes, we post advice and questions based on our geographic location. A good example: someone from Singapore asks "What's a heater hose?"
The hoses and belts in alpine climates are exposed to rather large temperature changes that may not be present in a more temperate climate.
Those who redline on a daily basis may have a different climate than you, newer belts, and they won't be paying to rebuild your engine.
Just my 2 cents: Let your engine thoroughly warm up (including belts and hoses) before you put your foot into it. Further north, this may not occur for several months.
PostPosted: Sun Dec 23, 2007 2:39 pm
Why would you want to redline your engine?
PostPosted: Sun Dec 23, 2007 5:29 pm
Well, if you're driving a swift GT(i), then thats the only way to get real power out of it:
http://csl.forcefed4.com/roydean/swift/rdgdspin.WMV
PostPosted: Sun Dec 23, 2007 5:32 pm
Regardless of climate or location - redlining an engine that has not been allowed to warmup would not be advisable - and - at least in my opinion, regardless of climate, location or ambient temperature, once the engine is at operating temperature, there is no danger in redlining it.
@dasaniracing - redlining the engine at least once a day reduces the carbon buildup that occurs on an engine that is operated only at lower rpms - for example a vehicle that never makes it out of the city traffic on to the highway.
PostPosted: Thu Jan 17, 2008 12:20 am
ok but i drive it on the highway from time to time. I just don't wanna mess up and blow my engine.
Well I left my car sitting for a week with out driving it and the battery completely lost power.
So I gave it a boost and drove it down to sear's auto shop and brought a brand new Diehard weather handler battery.
It started right up! but the real test will be when the temp. drops this weekend to below freezing !!! I hope it starts right up with out any problems. I will let you guys know what happens after this sunday.
PostPosted: Fri Jan 18, 2008 11:57 pm
how bout having lots of gas in tank and plugging car in ? thatd be the best to do ;)
bend it to fit and paint it to match ;)
PostPosted: Sat Jan 19, 2008 4:06 pm
want16v very funny :? i
PostPosted: Tue Jan 22, 2008 1:25 pm
well i brought a new die hard weather handler battery and it starts up with no
problems and no engine stall. even after very cold over nite temps.
thanks guys for all your advice. i
