It is currently Thu Jan 18, 2018 8:19 pm
 Post subject: High volume oil pump
PostPosted: Tue Dec 18, 2007 4:35 pm
Does anyone know if there someone who makes this for the G13B?
PostPosted: Wed Dec 19, 2007 8:51 am
Yes
http://www.importperformanceparts.net/i ... uzuki.html
PostPosted: Wed Dec 19, 2007 3:44 pm
Are there other options? I have some people that used this pumps on honda engine that had problems with it.
PostPosted: Thu Dec 20, 2007 9:56 am
Not that I know.
PostPosted: Thu Dec 20, 2007 11:09 am
Sometimes you can modify an oil pump so as to allow it to pump a greater volume. I've not had an oil pump off of a Swift before so I wouldn't want to say without looking, but oftentimes if you port the passages on the pump and/or shim it then it will pump a greater volume than when it was original. The risk with this of course is that you will suck your pan dry. I assume you already have an oversized pan with baffles since you're obviously serious about racing that holds enough oil to not have to worry about oil starvation. I don't know if you have a spare stock pump sitting around, if you do it might be worth taking a look, or if you could post some pictures I'd be willing to take a look and see if I could come up with a solution for you.
#82 1984 CRX Oval Track Racecar
#82 1987 Chevy Monte Carlo Oval Track
#82 1984 Porsche 944 Oval Track racecar
Maine Tuning and Performance
We are your source for speed and import parts and fabrication.
