It is currently Wed Oct 18, 2017 5:57 pm
PostPosted: Mon May 12, 2008 9:43 pm
Got the MegaSquirt all installed and ready to go. This is in a racecar so no idle wiring or stock harness. I'm using a relay board also. Went with the GM sensors so it would make it a little easier. Had them (DYIautotune) install the ignition drivers and I'm using a modified stock distributor.
http://i140.photobucket.com/albums/r31/ ... e486-1.jpg
Problem I'm having has me stumped.
When I crank the car over with the starter button I get zero RPM showing. If I take the dist out and turn it by hand at about the same speed I get a signel, the RPM shows on the comp screen, the fuel pump kicks on and I can hear the injectors. If I put the dist back in the head and crank it I get nothing. I've even tried turning the dist with it out of the head just enough not to engage with the cam but be grounded and it works. With the dist out, me turning it by hand and hitting the starter button, it gets a signal.
I've switched dist modules with zero change.
Any help, I have a big race coming up on the 24-25 I'm trying to make.
Thanks,
Suzuki Jon
#04 Suzuki Swift GTI SCCA GT Lite
Giving Suzuki it's first SCCA National Production win, and second, and third....
http://i140.photobucket.com/albums/r31/ ... 30ea_m.jpg
http://i140.photobucket.com/albums/r31/ ... ce_074.jpg
PostPosted: Tue May 13, 2008 11:36 pm
Put a voltmeter on that circuit and measure the voltage when it is cranking.
What does it show?
Pres
'89 -made in Japan
PostPosted: Wed May 14, 2008 2:25 am
Got a reply from the tech at DYIautotune thats been very helpful about "adjusting the VR input circuit potentiometers."
I checked the pots and found both of them turned 20 turns clockwise. I set both at full counter-clockwise. I found somewhere to set the R56 pot at full counter-clockwise and the R52 pot at 6-8 turns clockwise.
With them set there I got an RPM of about 175 RPM. Good progress!
Everything else looks about right on the gauges, temps, TPS, etc.
New problem, I get no power from the fuel pump relay and no spark. Do I have something else set wrong?
How do I adjust the pots so they are in their "happy place?"
Thanks,
Jon
Suzuki Jon
PostPosted: Thu May 15, 2008 1:31 am
It Runs!!!!!!!!!!
I put the stim on and adjusted the pots until the RPM signal was smooth, somewhere around 6-10 turns out. Plugged it back in the car and it sputtered, moved the dist around and got it fired up.
Set the dist by matching the timing on the megatune to the preset on the timing light and matched up the marks. Starts right up, now it's off to the dyno.
Looks like I'll make the Memorial day SCCA race at Miller Motorsports in Salt Lake City.
Suzuki Jon
PostPosted: Thu Mar 12, 2009 1:00 am
Could you post some pics on your set up im about to install a ms2 on my car and was planning on doing the same upgrade on the dis.. Any help would be appreciated. Thanks Stephen
PostPosted: Thu Mar 12, 2009 2:58 am
like me, youll probably run into some flaky rpm values at higher rpms. make sure you put shielded wiring on your dist pickup wires!!
and I still havent tuned my high rpm miss out, the log shows spikes to 144000rpm, and it seems the only way I can get them to stop leaves me with no rpm signal when the ecu is cold. ive been playing with it for months now and im ready to say fuck it and do a 36-1 already >_<
the lolcar family
