It is currently Wed Oct 18, 2017 1:45 am
 Post subject: MPFI G10
PostPosted: Sun Sep 14, 2008 6:45 pm
I am looking to use a G10 motor to drive a generator project i am working on..
i would like to have a MPFI motor.. the problem with this is that i cannot find any that are MPFI N-A. i have found a pic of a motor that was converted to be used on a airtrike it is MPFI.
what i am wondering is if they used a turbo motor and did not use the turbo
the link to the pic is
http://www.airtrikes.net/engines/large/jasons_g10_l.jpg
SAM
 Post subject: Re: MPFI G10
PostPosted: Sun Sep 14, 2008 7:40 pm
humm just read in a diff topic that the turbo ecu is batch fire on the injectors.. this will be some what pointless trouble if they are batch fire..
can some one verrify that the turbo is batch fire?
sam
PostPosted: Mon Sep 15, 2008 3:34 am
sam
Well you gotta do some more reading, if you want to just unblot a turbo, then expect the motor to run well, but it is possible to unturbo a motor though and have it perform well.
All Suzuki G series engines use BMPFI, if you want SMPFI, then you'll need to look into building a MS to replace the ECM, and setting it up for your motor to control the FI of your choice.
These engines were designed and built before cheap computers could handle SMPFI, and our cars are Econo Boxes.
PostPosted: Mon Sep 15, 2008 6:09 am
Gamefoo,
I think our engine is an exception, pretty sure the SOHC 16V is sequential. There are separate outputs from the PCM for each injector.
PostPosted: Mon Sep 15, 2008 9:06 am
yea after reading a bit i was some what afraid it was batch fire not sequential. so in short i dont want it bad enough to spend the R & D time to convet an ECU.
the only other option would but to purchase a EMS they are only about 1k http://www.sdsefi.com/specific.html this is a sister to the EMS that are used on the aircraft conversons.. the next problem that would come up is if i could get that system to work with the gaseous fuels i want to put on the generator skid..
Sam
PostPosted: Mon Sep 15, 2008 11:12 am
well i just sent SDSEFI a email and the SDS system is batch fire...
PostPosted: Thu Sep 18, 2008 7:53 pm
here's the write up for machining the injector ports on a n/a g10 head.
viewtopic.php?f=11&t=25103
my mk2 turbo3 rig uses one signal from the ecu for all 3 injectors yet delivers more precise fueling than the tbi n/a setup. it also gets better mileage.
PostPosted: Mon Sep 22, 2008 8:28 pm
I have searched around for a flywheel torque curve with the +10 cam installed and cannot seem to find one... does any one have one they would like to share..
From what I read every degree you advance the timing you lower your power band by 100 rpm.
This means with a +10 cam gear on a motor that is at 2000 RPM will be making the same torque as a stock motor at 3000 RPM.
Stock motor at 3000 RPM makes approx 55 ft. lbs so 3000x55/5252= 31hp
Stock motor at 2000 RPM makes approx 48 ft. lbs so 2000x48/5252= 18hp
So for a +10 cam gear I would make 55 ft. lbs at 2000 so 2000x55/5252 =21hp
Am I correct?
Only a 3 hp gain.
PostPosted: Tue Sep 23, 2008 12:15 am
Are you correct?
I doubt it.
Theres more to it than that.
If you were though, 3hp at 2000RPM would be huge, close to 15%.
PostPosted: Tue Sep 23, 2008 11:19 am
suprfly
do you have a FWP dyno chart for the 1.0l stock.
The problem i am having is i have located one chart for the 1.0 and it starts out at 2000 rpm but at 2000 rpm the motor is only making like 17 almsot 18 rpm.
i need about 30hp at 1800 rpm.
do you have a cam grind to make power at lower RPM
