It is currently Thu Oct 19, 2017 11:39 pm
PostPosted: Thu Oct 16, 2008 9:17 am
Hi gang, I had a Equus tach installed and you CAN set it up for a 3 cylinder.....it is reading ok until the secondary shift light on the dash comes on (about 4000 rpm), then the needle immediately goes down to @ 1500 rpm.
I am getting ready to bracket race this thing and just want to be able tyo launch at the same rpm all the time and shift at the same spot too.
36 time NHRA/IHRA Champion
05 SRT4 / 12.79 @ 111 mph / 40.1 mpg!
01 Voyager V6 / no mods yet / 24 mpg
84 Horizon / 1760 lbs / was 17.9, now 23.0 mpg
96 Geo Metro / 1590 lbs / was 46.2, now 60 mpg!
95 Neon / unk mpg so far
PostPosted: Thu Oct 16, 2008 1:45 pm
Problem solved.....the mechanic just had to move the inductive pick up wire clamp from #1 to the coil and every thing is working as it should.
PostPosted: Sat Oct 18, 2008 8:11 pm
what model tach? How much did it cost?
94 metro 4dr 1.0 AT
there are many, but this one is mine.
You say crazy like it's a bad thing!
