It is currently Tue Oct 17, 2017 5:32 am
 Post subject: e 3 spark plugs
PostPosted: Tue Nov 18, 2008 6:45 pm
Are any of you guys familiar with the e3 plugs?? are they any good?
Thanks for any info,Mike.
 Post subject: Re: e 3 spark plugs
PostPosted: Tue Nov 18, 2008 9:15 pm
Check out the thread on Pulstar.
PostPosted: Tue Nov 18, 2008 9:32 pm
I installed a set in a customer's vehicle per request. He claims no change in power or MPG.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Wed Dec 31, 2008 1:28 pm
Same concept as the 4 pointed Bosch plugs, just provides more area for the spark to jump to. But the spark only jumps to one spot at a time anyway, so the result is just a plug that wears more slowly.
Basically, the plug either ignites the fuel or it doesn't. Despite Pulstar's bullsh*t, the spark can't make the fuel burn faster or more powerfully. A stronger spark just provides protection against misfires.
PostPosted: Wed Feb 04, 2009 10:16 pm
I have the E3 plugs in both my cars and the seemed to run better then the bosh and ngks i tried. They are a hotter heat range plug so they probablly wouldnt be a good idea for boosted applications. And it was in both my gt's befor i forget to mention the motor. Just my 2 cents.
PostPosted: Wed Feb 04, 2009 10:37 pm
A legend in his own mind
stephennmm wrote:
I have the E3 plugs in both my cars and the seemed to run better then the bosh and ngks i tried. They are a hotter heat range plug so they look, I'm retarded wouldnt be a good idea for boosted applications. And it was in both my gt's befor i forget to mention the motor. Just my 2 cents.
QWALL, WOULD YOU LIKE TO COMMENT?
:mrgreen:
PostPosted: Thu Feb 05, 2009 3:14 pm
Ok im not sure whats going on almost everytime I send a message some how it manages to put this "im retarded" thing in the middle of a sentence and i look at it in the edit part and its not there. Is there something wrong with the server or something???
PostPosted: Thu Feb 05, 2009 3:38 pm
p-r-o-l-l-y = look, I'm retarded
08 Civic Wife's car
