It is currently Mon Oct 16, 2017 7:07 pm
PostPosted: Tue Nov 25, 2008 4:05 am
Hey everybody, I'm finally getting around to doing my 3tech economy head swap and I just want to see if there's anything else I should be doing while I've got it all ripped out?
So far the things I've bought are: Timing belt, water pump, complete head gasket set, headbolts, and an advanced timing sprocket
Is there anything else I could do while I'm at it to get more power or economy out of my shitbox?
PostPosted: Wed Nov 26, 2008 11:44 am
well power certainly isnt going to be a side effect of the econo package...
1989 Geo Metro LSI- THE BEAST
-Performance head package, header, drilled/slotted rotors, cut front springs, lightened flywheel, +10 timing advance, short throw shifter, modded exhaust
1997 Blazer
-Front lowered 2", euro taillights with LED light bar, clear corners, CAI, 31x10.50 Rear tire swap
1993 Dakota
- All stock, big ol v8 beast. Wanna buy it?
PostPosted: Wed Nov 26, 2008 1:27 pm
Actually, if you read the reviews, more low end power is a "side-effect" of the econo head package. Also, the advanced timing gear, match ported head, and higher flowing intake and exhaust mods should help that department out too....
PostPosted: Thu Nov 27, 2008 9:07 pm
:oops: haha forgot the existance of the low end.
1997 Blazer
1993 Dakota
PostPosted: Fri Nov 28, 2008 3:43 am
Haha, it's a pretty easy thing to overlook in a car that has about as much low end torque as a chainsaw... :D
PostPosted: Fri Nov 28, 2008 9:27 pm
Do yourself a favor and put new rings and rod bearing in while the head is off.
PostPosted: Fri Nov 28, 2008 9:41 pm
Singh Grooves..........................
http://www.jeremiahsviolins.com/grooves.htm
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Wed Dec 03, 2008 3:47 am
Thanks guys, hopefully I'll get to it this weekend...
