It is currently Wed Jan 17, 2018 10:26 am
 Post subject: Header Wraps
PostPosted: Thu Dec 18, 2008 2:44 pm
I was curious about these, google search and found a website that was against them and their reasoning.
http://www.centuryperformance.com/exhau ... g-138.html
* Header wraps are designed to keep the heat in the header to improve scavenging of the cylinders. Keeping the heat in the header allows the exhaust speed to remain high. (the right idea)
* There are no header manufacturers that I know of that will warranty their headers if any header wraps are installed on their products.
* In most cases the header wrap damages the headers beyond repair. (I will explain below)
* If you run a lean mixture, you "may" see a slim performance gain using header wraps. A rich mixture may show slim to absolutely NO gain in performance.
* If you do not mind replacing your headers and header gaskets regularly, and you like that ugly look of a wrapped header, go ahead and use the heat wrap.
If you want a true thermal barrier that will reduce thermal loss in the header, reduce under hood temperatures, and make a few horsepower in the process, have your headers thermal coated by one of the many companies available. Most all of the coating companies offer inside and outside, multi-layer coating as standard. DO NOT allow your headers to only be coated on the outside, this is not a complete or quality process.
my questions for the board would be: how much would it cost to get my 4cyl headers coated ? is getting the exhaust headers coated a good cost/performance modification ? would it be better just to wrap them ? do i even need to get a coating/wrap ?
 Post subject: Re: Header Wraps
PostPosted: Thu Dec 18, 2008 3:14 pm
King of Pompous
Why don't you just google thermal coatings and find a company nearby that you can call for a quote?
LNLC Founding Member
PostPosted: Thu Dec 18, 2008 3:39 pm
smart@ss
Yes.
No.
Maybe.
Any other questions?
I miss Jomo BRING JOMO BACK
mojojoeyjojo wrote:
PostPosted: Thu Dec 18, 2008 4:44 pm
banned and still posting
It cost about $120 to have mine coated, would have been less if I didn't want the shiny Ceramakrome coating.
PostPosted: Thu Dec 18, 2008 8:01 pm
He's even within driving distance of the place I used to get my headers coated, and they did an excellent job.
Kool Coat Ceramic Coatings IIRC
PostPosted: Fri Dec 19, 2008 7:55 am
I doubt there would be any noticeable performance gain, any difference will be quite subtle. If you're getting a header from SuzukiRD, I can see getting it coated for cosmetic/longevity purposes. Their chrome plating is awful and the header will look like shit in a month.
PostPosted: Fri Dec 19, 2008 8:03 am
^ That was my purpose. I wanted it to last and the rust was already taking hold on it.
PostPosted: Fri Dec 19, 2008 12:27 pm
i see, i guess this is not worth for me to get done, i'm not racing the car anyways.
PostPosted: Fri Dec 19, 2008 12:34 pm
LoL, still remember the guy saying, how some of the welds were amazing, and how some looked like shit, I told him the good welds was the work I had done to it. lol
One good thing about the shitty chrome was that it made sandblasting it off easy. :)
