It is currently Sun Feb 25, 2018 5:39 am
PostPosted: Sun Apr 12, 2009 9:13 am
Any older members please throw some light on it ... in terms of side gapped plugs harming ignition system or engine in any ways ???
I did it on my existing R8YC Champions and found my idling RPM more stabilised, engine much lighter now, more responsive and throttle friendly even with Air Conditioner full on.
I did it using a small hack saw and a small file.
Pic attached.
Thanks.
Cried for not having a Honda, laughed at Honda not having G13B motor.:ez_pimp:
PostPosted: Sun Apr 12, 2009 11:47 am
I'm an "older member" as you put it but I don't have a clue. 8)
:huh: It works. I don't see it as harming the engine unless or until the electrode wears off. Give it 500-1000 miles and check the plugs. It looks similar in design concept to my Bosch Platinum +4's only 1/3 the price. Of course there's the new E3 http://www.e3sparkplugs.com/ Which look funky, eh.
Very clever and creative... :mrgreen:
Have fun,
Bad Bent
PostPosted: Sun Apr 12, 2009 4:07 pm
Here's a factory side gapped plug for ya. 5/8" hex, 3/4" reach, 14mm thread. Heat range? I don't know..... Cool design though.
NGK2288
Originally designed for a 2000 Porsche 911 3.4 litre. It would fit in a Suzuki engine.
Strangely, Champs, Bosch, Autolite, ETC, for the same application is a conventional plug. Only the NGK has this design.
PostPosted: Sun Apr 12, 2009 10:13 pm
For quite a few days I wasn't happy with the acceleration of the car but side gapping my plugs has made a remarkable change and at the cost of repetition my idling rpm has now stabilised as if i have cleaned my IAC valve, whereas I haven't touched that since I installed an oil catch can.
PostPosted: Sun Apr 26, 2009 9:41 pm
Never heard of it. I assume the theory is just by removing the metal above the electrode theres nothing to get in front of the flame front?
1990 Turbo Firefly
PostPosted: Mon Apr 27, 2009 7:51 pm
:huh: Bosch seems to have a similar design to the NGK... patents, eh. I love my Bosch +4s. I think you are right fitsandy, they do make a difference. Your butt Dyno seems well tuned. I am doing an oil catch can also.
3pontiacs, I think you are correct. :D I've heard the term "Squashing the Flame" as it applies to plugs. Seems to work well for us to remove the electrode from above, er... below the spark. Nothing between spark and fuel, more even burn pattern?
Have fun,
Bad Bent
PostPosted: Wed May 06, 2009 9:48 pm
So reading up on this more, it sorta makes sense, but it goes back to the original question, is this harmful to the Ignition system or the engine?
PostPosted: Wed May 06, 2009 11:14 pm
When you increase the travel space between the two points you increase the amount of voltage required to fire. So as long as you keep the gapping correct, it should be fine.
My cars:
PostPosted: Sat May 23, 2009 11:20 am
I think the tip of the spark plug would corrode or carbon up faster or whatever you call it. Might be good for short-term, but how much of a difference could it possibly make really, outside of being a placebo.
"Apollo 13", 436,600km | 89 Swift GTi -dead-
91 Pontiac Firefly.
