It is currently Wed Jan 17, 2018 3:22 pm
PostPosted: Sat May 30, 2009 10:38 pm
i tried searching for some info, but didn't get what i expected..
the crank in this '94 metro i'm rebuilding is sorta in bad shape... i have a crank and set of rods out of a '92 g10 turbo that are in great shape.
will the crank & rods perform well in an n/a g10 block? -with standard turbo pistons?
do they use the same size main bearings?
i kinda like the idea of a floating wrist pin, but are the pistons of the same compression ratio?
what do you guys figure?
;) :lol:
PostPosted: Sun May 31, 2009 10:36 am
the crank is the same, it's been discussed many many times.
the pistons have a lower CR.
Suzuki Gold Master Tech
PostPosted: Sun May 31, 2009 2:52 pm
and the rods are different... REQUIRING you to find different pistons
n/a is a 17m pressed pin whereas the turbo has 19mm floating, it is stronger, but the 17mm lighter rods perform well. the rods are a different weight so to avoid any minor balance issues, keep the rods with the crank if you have both.
you will not find factory turbo pistons anywhere anymore, I had a used set I sold for 100 something. the turbo pistons also have some factory coating on them, and are discontinued.
I made 110whp with more to go on the n/a stuff, so im not sure what you are after, but hope this helps
the lolcar family
PostPosted: Sun May 31, 2009 9:18 pm
thanks for the info!
;) :lol:
