It is currently Thu Oct 19, 2017 6:05 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 24, 2009 11:07 am
and i'm starting to think that it has nothing to do with the engine just some sensor or ignition problem. I think sense I put the new o2 sensor in it's now running rich but I don't know.
PostPosted: Fri Jul 24, 2009 1:00 pm
gbabysurfer wrote:
ok so I just did a compresson test on my car and there is no way that it can be running this bad and have these kind of compresson results.
dry cranked till gauge stopped going up
1. ? (was being stupid and put oil in it before i did the dry test)
2. 230
3. 230
4. 235
wet cranked four strokes each
1. 230
2. 230
3. 230
4. 280 ( I did it three times and this is what I got?)
So I'm really up shi-s creek. I do have a code 51 and I looked it up and have no idea what it means but before I had that I had a code 13 so I replaced the o2 sensor and then I had a code 21 or 22 forgot belive 21 so I did the check on the tps with the workshop manuel and it seemed to check out and now it is throwing me 51? Is this my problem and what should I do next?
Wow, this is getting really exciting.
Could you post some pictures of your compression gauge and vehicle please.
PostPosted: Fri Jul 24, 2009 1:18 pm
2. 230
3. 230
4. 235
1. 230
2. 230
3. 230
I believe you are not performing these compression tests correctly. You should have around 200-210 in a *brand new engine*. My 1989 Swift GTi shop manual says "standard" is 206.2 psi/14.5 kg/cm2.
And what makes you think it's running rich now?
PostPosted: Wed Jul 29, 2009 7:29 pm
Ok so I'm thinking about buying the suzukird high comp race pistons and I was just wondering if I ran 11:1 comp what gas would I have to run to have it work right.
PostPosted: Wed Jul 29, 2009 10:43 pm
So what ever happened to your compression test?
PostPosted: Thu Jul 30, 2009 10:59 am
I would definately sort out the "what is actually wrong with it" question before i went and bought high comp pistons. What if it is a sensor/wiring issue?
