It is currently Wed Feb 21, 2018 2:21 am
 Post subject: Bigger Better
PostPosted: Sun Dec 13, 2009 2:06 pm
If I was to do a resize on my cyls would it be a worth while power benifit to go as big as I can? Also is it worth advancing cam timing on a stock engine? How much?
Thanks
Go fast her eh ?
SCIENCE IS A WAY OF THINKING...Carl Sagan
 Post subject: Re: Bigger Better
PostPosted: Sun Jan 03, 2010 2:00 am
Well, "Nothing beats cubic inches" eh. :lol:
You could shave the head a little, depends on what you are trying to accomplish. If you need to, because your compression is below 156, then go for it if you want a few more horses. However you will likely need to raise the fuel octane if you get a higher compression ratio. So much for fuel savings.
The plug-and-play method would be a 3Tech 218/350 cam or the full 222/365 race cam and +10 deg. cam gear. This changes the dynamic compression, not the compression ratio. http://cochise.uia.net/pkelley2/DynamicCR.html
From what I have read it is good to advance the timing to 8 degrees BTDC for a little more power and a little less carbon build-up.
Regarding your other post, the only way to know your horsepower would be a dynamometer test. One could speculate but that's only opinion.
Have fun,
Bad Bent
PostPosted: Sun Jan 03, 2010 1:12 pm
Thanks Bad, ya cubes eh, hard to beat, especially back when gas was cheep. Nothin like a BB.
All my engines have good cyls and don't need to go bigger, I was just curious if it was worth the extra $$.
I have looked into 3Ts goodies, look good, plans in mind :D
Can't wait till I have time to play !
PostPosted: Sun Jan 03, 2010 2:26 pm
Well, we don't need to go bigger. :roll:
"I was just curious if it was worth the extra $$"
It's that word "want" vs "need" conflict that always gets in the way.
My Geo acts like a strong 4 cylinder now. I believe it's doing quality spark, breaths easy, has more dynamic compression and is less constipated. I think I want an MSD 6A ignition box and have to justify the money for used or new w/warranty. Fish or cut bait. :thwack:
At every turn I have upgraded whatever I put on my car.
Have fun,
Bad Bent
