It is currently Wed Oct 18, 2017 5:22 am
 Post subject: chassi strengthening
PostPosted: Fri Apr 23, 2010 1:37 pm
hi
any tips on the spots to be strenghtened (welding)
any pics or diy?
thank you
91 swift mk3 gti
91swift mk3 gti
94 audi s2 coupe
01 mk4 golf gti
 Post subject: Re: chassi strengthening
PostPosted: Sun Apr 25, 2010 10:42 am
Check the rocker arms for rust, the whole undercarriage and especially the forward frame stands.
If you want to fabricate then you could add braces similar to http://www.turbinetech.ca/produits.php?sous_cat=44&lang=AN.
I'll add that a zinc paint, Ospho or http://www.theruststore.com/Evapo-Rust-Gallon-P1C1.aspx would remove the rust and help in diagnosis of what issues you have.
Look around: http://www.teamswift.net/gallery/image_page.php?album_id=758&image_id=17937
Have fun,
Bad Bent
PostPosted: Sun Apr 25, 2010 9:40 pm
You could make your own subframe connectors like they make for Mustangs....
PostPosted: Mon Apr 26, 2010 7:13 am
Rocker arms? :P
PostPosted: Mon Apr 26, 2010 11:17 am
I have one of these:
http://cgi.ebay.com/ebaymotors/UNIVERSAL-ADJUSTABLE-FLOOR-BAR-STABILIZER-STRUT-BRACE-B_W0QQitemZ330357758461QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item4ceadb59fd
Have fun,
Bad Bent
PostPosted: Mon Apr 26, 2010 5:00 pm
i used one of those in my twincam vert. it really did help stiffen the chassis and get rid of the rear cowl shake on that car.
on the bad side, it got in the way of the seat adjustment and in a hatchback, the rear passengers would hate you. :lol:
PostPosted: Tue May 18, 2010 12:18 pm
Or do this:
http://www.aijaa.com/v.php?i=6215762.jpg
That really works. But that pic is bmw's chassis...
Just weld every body seam, inch welding and then, inch without.
suzuki SA310/swift -86
Small but POWERFUL
0.050" milled head
littlebit ported head
basic valve mods
cold air intake
selfmade exh.manifold
1 7/8" exhaust
cat removed
Better ignition coil
8mm silicone ignition wires
PostPosted: Tue May 18, 2010 5:03 pm
suprf1y wrote:
Rocker arms? :P
I meant control arms.
Have fun,
Bad Bent
PostPosted: Wed May 19, 2010 6:35 pm
I think the proper term is 'Stub Arm'.
Control Arms are the bits with the ball joints in/on em.
My cars:
PostPosted: Sun Jun 13, 2010 11:08 pm
SA310 wrote:
Or do this:
I have no idea what I'm looking at in that pic...
PostPosted: Mon Jun 14, 2010 7:07 pm
it's just a pic to illustrate additional weldments to strengthen a chassis. generic stuff, but very labor intensive.
i rallye prepped a 1974 saab 96 sedan with gussetts and additional welding and it took me months to get through it. (the saab is still around 26 years later and the steering wheel is in my closet. :lol: )
PostPosted: Wed Jun 16, 2010 4:42 am
I done it 2 weeks...
Small but POWERFUL
0.050" milled head
basic valve mods
cold air intake
1 7/8" exhaust
cat removed
PostPosted: Wed Jun 16, 2010 8:58 pm
How much you want to stiffen your chassis depend what you want to do. 16 gauge rocker panels, seam welding and a roll cage stiffen the chassis up.
Dan
DSCF2658.JPG [79.54 KIB]
Downloaded 1282 times
PostPosted: Mon Jun 21, 2010 12:16 pm
Dan
Wheird, I swear that cage looks like its built to rally specifications...
GeoZukiGTi wrote:
CJDavE wrote:
Chassis Flex Motorsports
