It is currently Tue Oct 17, 2017 9:27 am
 Post subject: carb intake
PostPosted: Fri Sep 24, 2010 4:41 pm
does some one were can i get this intake or something similar????
suzuki forsa 1985 (SA310) with g13bb swap>>SOLD!
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
 Post subject: Re: carb intake
PostPosted: Sat Sep 25, 2010 12:08 am
That's a 4 barrel bonnet with a custom bottom plate to fit the tbi. Probably Vortech supercharger. Looks real good but it's sucking hot underhood air. You need to be pulling ambient temp outside air with some ducting. There's a bunch of junkyard chrysler minivans with adaptable rubber bonnets that could be adapted to flex hose and run out the pass side fender hole that would work a lot better.
Pick n Pull FTMFW!!!!!!
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Sat Sep 25, 2010 2:06 pm
yes is know is sucking hot air that is why i just want the hat so i can adapt a flexible to the front or the car to get cold air but were cani get one :huh: or you say from a minivan wich one?and what year? i like the idea of the minivan thing sound cheap :D
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Mon Sep 27, 2010 10:08 am
maybe mazda 323 carb induction is similar one.
http://motorcade.co.za/index.php?main_p ... age&pID=33
OR
http://www.autostyle.co.za/product/12001/SimotaAdaptor/
suzuki SA310/swift -86
Small but POWERFUL
0.050" milled head
littlebit ported head
basic valve mods
cold air intake
selfmade exh.manifold
1 7/8" exhaust
cat removed
Better ignition coil
8mm silicone ignition wires
PostPosted: Mon Sep 27, 2010 7:17 pm
SA310 wrote:
thouse look really nice but are just to expensive for me like the idea of the minivan better
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
