It is currently Thu Oct 19, 2017 1:14 pm
PostPosted: Sat Jan 15, 2011 9:14 pm
Ok here's the story...
I just change the clutch cable because it broke up... and now "i think it was all fine... but i commited a huge mistake...
i connect the car battery on the wrong way, the positive side on the negative side (i accepted boos from you guys) and well once i turn the key to start the car there's no response.
So i want to know if the car (a suzuki swift 1991 manual 1.3lts) have a computer or something similar... so i can identify the problem and fix it... :( :oops:
Since im new to the suzuki swfit engines i really want to learn the possible of the impossibles.
Greetings From Mexico...
Frankie Alva.
PostPosted: Sat Jan 15, 2011 11:52 pm
Welcome, Frankie.
No problemo.
Just put the battery back in the right way.
It might have blown a fuse.
If so, just replace that and you're good to go.
Been to Los Cabos a couple times; nice place!
PostPosted: Sun Jan 16, 2011 12:50 am
I did the same once, not watching what I was doing. It blew the main fuse in the fuse/relay box next to the battery.
PostPosted: Sun Jan 16, 2011 1:53 am
Phil N Ed wrote:
Welcome, Frankie.
No problemo.
Hey Phil... I Put It back on the right way and stills the same... i check the fuse box and it was a few ones "burned" i replaced it and stills the same :(...
Have you been in Cabo Before!!! Great... any plans to comeback soon???
Greetings!
PostPosted: Sun Jan 16, 2011 2:03 am
Wow!!! U Just Saved Me... let's replace that Fuse.. i'll look for it tomorrow early morning!!!
Thanks A Lot!!! :D
PostPosted: Sun Jan 16, 2011 6:22 am
If I remember correctly, it was yellow with a clear top (so you can see it"s blown). I think you need a cross type (Phillips) screwdriver to remove it.
PostPosted: Sun Jan 16, 2011 6:32 pm
I Did It Early Morning after an exhaustive Check Of All The Fuses On The Car!!!
Thanks... and Also i'll be a fan of this forum... Great Friends All Of You!!!
But Hahaha... i just saw the Main Fuse and it has like 2 "legs" and well i guess it's gonna be hard to find here in Mexico... but i'll try to get it ASAP...
Also Thanks for the wiring Diagram Posted Here!!! Soon My 91' Swfit Willl Be A Part Of Me Too :D
PostPosted: Sun Jan 16, 2011 10:50 pm
you can jump that fuse by connecting a wire to both sides or with the battery off the car you can fold those legs down on to each other and it should get you running. You might want to swap it at some point though.
PostPosted: Wed Mar 02, 2011 11:24 am
It might be attached with two Phillips screws, so consider that when you try to pull it out.
PostPosted: Wed Mar 09, 2011 12:56 pm
This ^^^ is not...I repeat...NOT a safe thing to do. If you just want to get the car started, I guess its okay, providing you are certain that you have no shorting circuits...otherwise, get it done correctly.
~the other Ralph~
Certified Suzuki Owner:
