It is currently Thu Oct 19, 2017 10:10 am
PostPosted: Sun Feb 13, 2011 7:51 pm
i have a 94, metro 3cyl.
i have installed front and rear sway bars out of a 1995 metro. The exhaust shakes much like the engine and the result is, that the pipe swings one way and it hits the rear sway bar. It then bounces off of that and hits the right rear lower control arm. the noise/rattle is constant wether its high or low rpm's, and it drives me nuts!
im in a toss up ...do i buy a completely oem restrictive exhaust and pay the price for a quiet ride?
or is it actually possible to upgrade the exhaust to maybe a less restrictive 1-3/4" or 2.0" without sounding llike a fart pipe? I wouldnt mind a little louder than stock, but fart pipes drive me nuts too.
I was thinking of installing cherry bombs/ glasspacks in every straight section of pipe.
For example, first the manifold/header and cat, then 1 or 2 glass packs, then the 90degree bend to the right side of the car, then maybe another where the stock muffler was. I would think with 3 cherry bombs it should be fairly quiet even if it was 2".
AND FINALLY would it be a better idea to do a solid mount exhaust with a flex pipe? That way when the flex pipe goes its only a $20 fix?
What is everyone else doing to get around this problem?
PostPosted: Sun Feb 13, 2011 8:40 pm
check your motor mounts
PostPosted: Sun Feb 13, 2011 8:57 pm
just checkedem theyre fine
PostPosted: Sun Feb 13, 2011 9:37 pm
no issues with mine hitting,2 inch from manifold back,no cats/resonators,only stock muffler.DOES NOTsound like a honda....
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Sun Feb 13, 2011 9:40 pm
got an audio clip by any chance?
PostPosted: Sun Feb 13, 2011 11:20 pm
im on the same boat as you are, right now. i would want to go all the way SS but with headers. but quite honestly, im not so sure about spending 700 on the exhaust project till im sure how much would it be to do a complete engine rebuild cost. keep us updated... my thread is on the mk5 north american swifts -- re:need help on exhaust"
lol, see you there...
PostPosted: Tue Feb 15, 2011 5:05 pm
still no update HEY blueturbofly you said you have a 2" pipe and a stock muffler isnt the stock muffler inlet 1.5"? Did you get an adapter or did you find an oem replacement with a 2" inlet?
PostPosted: Tue Feb 15, 2011 5:46 pm
Go 2" with 1 glasspack after the cat and see if you like the sound. If not, you can always add one more glasspack at the very back. With a cat, and 2 glasspacks, it will be quiet.
PostPosted: Tue Feb 15, 2011 6:50 pm
can i buy a 2" mid pipe or am i better off having one made?
PostPosted: Tue Feb 15, 2011 6:52 pm
Make a few calls, and find an exhaust shop that does custom work for the right price.
PostPosted: Tue Feb 15, 2011 10:27 pm
i had the muffler shop stretch,or expand, the muffler inlet to 2 inch inside diameter.stock muff,one in=two out
3 tech 6*gear
gti brake swap
